Question about XEROX MULTIFUNCTIONS Xerox Phaser 6180mfp/d - Multifunction Fax / Copier / Printer / Scanner - Color - Laser - Copying up To: 20 Ppm mono / 7 Ppm color - Printing up To: 31 Ppm mono / 20 Ppm color - 400 Sheets - 33.6 Kbps - Parallel, Usb, 10/100 Base-tx - Phaser 6180mfp
Xerox 6180 printer registration sensor test - XEROX MULTIFUNCTIONS Xerox Phaser 6180mfp/d - Multifunction Fax / Copier / Printer / Scanner - Color - Laser - Copying up To: 20 Ppm mono / 7 Ppm color - Printing up To: 31 Ppm mono / 20 Ppm color - 400 Sheets - 33.6 Kbps - Parallel, Usb, 10/100 Base-tx - Phaser 6180mfp
Xerox 7345 error 008-164 paper is folded with jams and 008/164
That error indicates that the paper was not sensed as passing the pob sensor which is right at the registration rollers. If the paper is folding there, the main cause is the registration clutch not being initialized or slipping. Replace registration clutch, part number: 121K22220
http://www.iteminconline.com/121k22220_121k22220-xerox-7760-registration-clutch.htm
Mar 25, 2016 | Xerox Workcentre 7345 Printer, Copier,...
Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
Good luck.
Oct 06, 2014 | Xerox Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
I have an older Phaser 6180 printer that was never used until i opened the box today. I think it was a 2007 version but never opened. I connected it to my windows 7 computer with usb and while...
You most likely need a Windows 7 printer driver.
Go to the Xerox WEB site to download the printer driver -
http://www.support.xerox.com/support/phaser-6180/downloads/enus.html
Jan 19, 2011 | Xerox Phaser 6180N Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180 lost CD...
the local or network option happens when you install it, install as a local first, then select it as a network option, assuming you have xp.
Aug 19, 2008 | Xerox Phaser 6180N Laser Printer
XEROX MULTIFUNCTIONS Xerox Phaser 6180mfp/d - Multifunction Fax / Copier / Printer / Scanner - Color - Laser - Copying up To: 20 Ppm mono / 7 Ppm color - Printing up To: 31 Ppm mono / 20 Ppm color - 400 Sheets - 33.6 Kbps - Parallel, Usb, 10/100 Base-tx - Phaser 6180mfp  Logo
120 people viewed this question
Top XEROX MULTIFUNCTIONS Office Equipment & Supplies Experts
k24674
Are you a XEROX MULTIFUNCTIONS Office Equipment and Supply Expert? Answer questions, earn points and help others
