Question about Toshiba 25 PACK DIGITAL STYLUS PEN FOR M200 M4 R10 TABLET PC (PA3316U2PK25)
Toshiba tablet Portege M205 stylus tip is worn out
How do I change the worn-out tip in Toshiba Portege M205 Stylus?
5 Suggested Answers
SOURCE: Replacement Stylus for tablet?
i just happen to have come across this site while looking for another stylus as well, so i went back to my google search and found this :D
http://www.adorama.com/WABP.html?sid=1216684387994534
what a coincidence eh?
Posted on Jul 21, 2008
SOURCE: how to repair a toshiba portege laptop m205-s810 screen and where to get one
http://www.cuzwesaidso.com/archives/000773.html
the screen mask is what is cracked.
Posted on Dec 25, 2008
anjana03
  • 361 Answers
SOURCE: Touch Screen not working or Pen?
in my opinon. you should be re instal this touch pad driver.
Posted on Jun 13, 2009
  • 7993 Answers
SOURCE: I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip.
Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside.
Press gently but firmly to make sure it is holding.
Hope it helps.
Posted on Aug 22, 2009
  • 14 Answers
SOURCE: how do I unlock my Toshiba Portege 3500 Tablet PC
If you want the fast way, then probably you have to rely on a third-party software. Take a try this password recovery software, it should help clear and reset the lost password and bypass the locked computer.
Note: you can do this on your own, no need to send the PC to anybody for any repair because it's dangerous for your private information stored on the computer, best regards.
Posted on Nov 13, 2011
I am having a toshiba portage m205 with win xp . Windows got crashed when I tried to load windows with recovery cd It doesnt recognize its recovery disk Pls help .
Hello
you can do one thing
with that your data will be saved.
try a bootable cd of win XP & install os again without formating C: Drive, just overwrite the os instalation in same drive.
maybe after that your problem will be solved
Thanks
Dec 30, 2010 | Toshiba Portege M205-S810 Tablet PC
How do I open up a Toshiba Portege M205-S809?
You can do it in the following methodology
http://www.irisvista.com/tech/laptops/ToshibaM205/Portege_M205_disassemble_1.htm
http://www.irisvista.com/tech/laptops/ToshibaM205/Portege_M205_disassemble_2.htm
http://www.irisvista.com/tech/laptops/ToshibaM205/Portege_M205_disassemble_3.htm
Nov 29, 2009 | Toshiba Portege M205-S810 Tablet PC
Hope it helps.
Aug 17, 2009 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
How to use the toshiba pen
First, go to your control panel and find the icon for the pen. Next, calibrate the pen and set up how you want it to work. The pen is not for use in every program necessarily but with handwriting recognition activated and a charactes set entered, it will wirk. It is also good for graphics, with a bit of practice. Some units let you erase with the back of the stylus, just like a pencil eraser.
Jan 08, 2009 | Toshiba Portege M205-S810 Tablet PC
Toshiba Portege Video problem
I found the same problem on one that I bought from a guy for $100. He had been picking it up by the screen and every connector in the screen and the pivot came loose. I was able to tighten every thing back up and now I have a real nice laptop.
Aug 12, 2008 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
340 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Roshan Rijal
Roshan Rijal
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
