Question about EliteGroup PM800M2 Motherboard
My usb ports on the back of my motherboard dont work
None of my usb ports work and my lan connection on the back dosnt work i have installed a usb expansion card and it seems to be working fine
    President:
  • 2,992 Answers
Check that the USB and LAN functions are enabled in the board's BIOS setting. If everything is set properly and they still don't work, you could have a bad motherboard. Check into the warranty if the board is new enough, or just use expansion cards to replace the lost functions.
Posted on Jan 27, 2009
FACK YOU
USB ports won't work on my ASUS PA 246, any idea why?
Which ports? front or back. The back ones could be because you don't have the drivers installed. The front ones could be because they aren't connected to the motherboard. If none of them work then it is likely to be because your USB controller has failed. You can fit a PCI card to provide some if necessary.
Sep 12, 2013 | Computers & Internet
How to install internet connection on my HP mother board
Hi.
If your motherboard have USB ports.available gadget USB LAN and USB WIFI gadget.
Just install driver software and search internet provider for internet access.
See sample picture USB LAN and USB wireless type gadget.
Jun 15, 2011 | HP Compaq Motherboard
My compaq G60 laptop dont have ethernet lan driver how i can solve this.
buy a adaptor callled "USB LAN adaptor" ....connect to ur USB port and then connect the LAN cable to that adaptor...ur USB port turns to a LAN portb67261b.jpg
Feb 02, 2010 | HP Compaq Presario F500 F700 and G6000...
We have recently purchased an Intel I7 processor and installed it into the ASUS P6T motherboard. We have also installed Windows 7 OEM builders operating system (not an upgrade version over windows XT). The...
Run "Windows Update", to see if it will find updated device-drivers for the specific USB hardware on the motherboard.
Access the ASUS web-site, and search for 'P6T', and search for USB device-drivers for Windows 7 -- if none are found, try the device-drivers for Windows Vista.
Jan 22, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
Usb ports on motherboard are not working. They do not seem to have any power. None of the ports work. Not even the front ones. I've tried reinstalling the drivers, installing different drivers, I've...
If the usb ports don't seam to have power, I suspect that at some time something was plugged into one of the ports, either at an angle or upside down, shorting the +5 vdc supply. Usually the supply voltage is fed to the ports thru a "zero ohm resistor", basically a fuse that blows protecting the power supply. You may be able to find and replace it but much easier is to install a 4 port usb pci card. They're cheap and you can go to 2.0.
Jan 13, 2010 | EliteGroup P4M800-M7 Motherboard
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
You have to install lan card driver to show your lan connection.
Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
Aug 26, 2008 | ASUS P5RD2-VM Motherboard
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Lan ports dont work
Where you able to check the Network adapter on the Windows Device manager?
How to verify your Network card is working properly
If you are unable to resolve the problem with your intergrated lancard then you can add additional LAN CARD on your computer or you can also buy USB to LAN CARD adapter.
http://www.techdeals.eu/electronics-store/images/tduc0205-1.jpg
Mar 07, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
EliteGroup PM800M2 Motherboard Logo
189 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
