Flashing signal saying door - Washing Machines
Door is only closed on first Latch, Push door more forcefull, could also be brocken Latch or Micro schwitch
Posted on Jan 22, 2013
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 | Dishwashers
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
Red light continues to flash to say that the door is open. Door is actually closed,but will not go onto program as the machine thinks the door is open.
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Hotpoint WMA32 Front Load Washer
Can enter code on keypad to lower garage door, however keypad just "flashes" when code is entered to raise door
If your other remotes are working normally I would suspect first of all a weak battery in the keypad. Secondly the keypad could be getting weak and the closed door blocks enough of the signal to cause your problem. An open door lets the signal through. Normally during the time the keypad is flashing you can hit 'enter' again to reverse the door if it is closing or stop the door if it is opening.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Beeps while driving
My van did this aswell, you must have a power sliding door, when it is not latched properly this warning goes off but it won't say on your message center "door ajar". Stop and reopen the door and close it again no more bell. good luck.
Aug 19, 2009 | 1999 Pontiac Montana
Turn signals dont work
The door lock problem and turn signals are likely unrelated unless there is a fuse that supplies power to both and the turn signal lights simply do not light. Check the fuses. If the turn signals come on but just do not flash, replace the flasher relay. It is located below the left hand side of the steering column.
Aug 03, 2009 | 1999 Buick Century
1995 Buick Regal with door and turn signal problem.
If it will not open from the outside it could be that the clip came of of the handel inside of the door panel.turn signal could be that the bulb is bad even if it lights up if it doese not flash it is a bad bulb
Mar 17, 2009 | 1995 Buick Regal
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Lights flash when opening power doors
when you open the power sliding doors the turn signal lights are supposed to flash. are there other lights that flash?
Dec 29, 2008 | 2005 Dodge Caravan
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
