Question about Sceptre X9G-NagaIV 19" LCD Monitor
Montior Repeatedly Shuts Off/Goes Black
History:
First, I purchased this Sceptre X9G Naga-IV back in December of 2005.
I hook this monitor up to my computer via the DVI connection.
Problem:
The problem I am having is that the monitor repeatedly shuts itself off (after about 10-20 seconds), the power buttons are still lit but the screen is completely black as if it is off. I can turn it off and back on and it will come back on but it will then shut off again after the same timing given above.
I have tried hooking the monitor up to another computer of mine (once again via the DVI port) and it acts the same with the other computer leading me to believe this is a problem with the monitor itself.
Does anyone know what could cause the monitor to act this way and how or if I might remedy this?
  • abhuiyan1 Mar 02, 2009
    I have acre 19" monitor. Bought last year. I am having the exact same problem?
I have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Posted on Feb 02, 2009
I've had the same issue starting on my Sceptre, it has coincided with a pure bright white screen appearing when I turn the monitor off, and when the signal from the computer is gone (computer off, monitor auto shut off). I've had to unplug the monitor each time I turn it off, and when I turn it back on this black screen (though only takes about 2 seconds until mine darkens).
I've temporarily "fixed" it, it works ok if you just turn it on and off repeatedly, eventually one of the times it turns on it stays normal for as long as I have it on.
Posted on Feb 16, 2009
  • 6,784 Answers
This model may have a built in stand by mode separate from your OS command. this is easily fixed buy using the physical buttons on this monitor. other than that, you may have a manufacturing run that has been shipped nation wide with this major flaw in design.
Posted on Jan 28, 2009
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the...
It may have dying power supply due to bad DC filter caps like the 17" version.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9G Komodo IV 19 in
check out any dry solder or burnt and re solder it , hope it helps AJ
May 03, 2008 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Getting the monitor apart
It is clipped on, or there is a hidden screw underneith a sticker or something.
They make these things hard to disassemble for a reason. There is very little you can do one you've got it open. There's almost nothing inside that can be serviced by any normal user.
Jan 23, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Flashing green power indicator lamp.
Check out the data plug- you may have bent some pins.
May 31, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-NagaIV 19" LCD Monitor Logo
633 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
