Zanussi ZWF1437W E23
I have a 2+year old Zanussi ZWF1437W that will not wash or rinse, spin and drain appear ok. An old item disintegrated whilst being washed and clogged the filter, once cleared, pumps and pipe work checked and cleared as required, the machine skips to drain if started at the prewash, wash or rinse cycles. When manually filled with water the drain pump empties quickly with no strange noise and appears to be good, cycle then ends as normal. When interrogated the machine shows a fault code E23, if cleared it reappears straight away, please advise as getting a bit fed up now. Many thanks in advance.
  • 15,935 Answers
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Zanussi zwf1437w
Possibly blocked sump hose( bottom of drum) or pump not running,,,,drain water by putting outlet hose down too ground level, when water drained out put machine on spin. If machine spins ok, then you have a pump problem,,,,if water won't drain out when outlet hose at ground level then you have a blocked hose
May 25, 2013 | Washing Machines
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Zanussi washer machine zwf1621s does a washeing
3 things you need to check : DRAIN MOTOR PUMP ,
LID SAFETY SWITCH & THE MAIN TIMER , hope it helps , AJ
Dec 27, 2009 | Washing Machines
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
