SOURCE: How do I remove the list of blocked calls on Panasonic KX-TGA470
Note: the handset is model KX-TGA470. The phone base system model may be KX-TG7731 or another KXTG7741. Other model numbers also use this handset.
You have to remove the entries in this list individually. Press Menu followed by the following # 2 1 7 . Select a number in the Blocked call list (with the up/down arrows) and select Erase. Use the up/down arrows to highlight Yes and then press Select. Alternatively, you can use navigate the menu system and look for Initial Setting and then Call Block. Press Select to enter the sub-menus. See page 41 of the manual for the section on Editing the Call Block list. See page 37 to see the menu tree for the Initial Settings sub-menu. The manual is available here: https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/KXTG263SK.pdf .
I hope this helps.
