Pioneer projection tv comes on when you plug in but goes off when start up model number sd-p5004
    Sergeant:
  • 250 Answers
Its the problem of the small electrical components getting overheated on the main power supply board .either the components are got loose or ther are at the last stage of turning faulty.you will require a meter to check out the faulty component.
Posted on Jan 27, 2009
I press bottom tv comes on then goes back off
On this model the power board will need to be completely resoldered, that is your problem.
Nov 29, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Singer TV Model 20LNC
while it goes off does it make a ticking sound?
Jun 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer Model SD-P4571 Problems?
It could be because of where you live.
Hi humidity, High temperatures where you live, etc.
Try placing a cooling source next to it, like a small portable air conditioner and even a fan.
Also, please try installing a GFCI outlet AND plug a surge protection outlet strip for all components and tv.
Any spike in your electric circuit, for example, a refrigerator starting, a furnace running etc. can cause the tv to turn off.
Regards,
Yalmer
Mar 13, 2008 | Televison & Video
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Help
Hi tedski have a tech look at your tv the problem is in the power supply or related circuit.good luck
Apr 26, 2007 | Pioneer SD-P50A3-K TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
