Dont clear my benq ppc p50 why - Office Equipment & Supplies
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
How do i unlock my phone
Use the Unlock code to Unlock the Benq P50 Phone from Network Lock,Specify the Network it locked now,Country?
Get the code at here
Theunlockspot.com and Unlock it.
Aug 15, 2011 | BenQ P50
Necesito el software para conectar con exito, el benq p50 a mi pc
Debe instalar Sincronizaci?n Activa de:
http://www.microsoft.com/windowsphone/en-us/apps/65-downloads.aspx
Manual:
http://docs.phonedog.com/benq-p50-manual-4016.pdf
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Jan 24, 2011 | BenQ P50
Installing wireless radio
Did you try a hard reset?? try it,, and let me know... good luck!!
May 23, 2008 | BenQ P50
No file association with mpeg
Yes!!!! try to use the TCPMP player software,, its plays almost every video anda audio format... good luck!!!
Apr 07, 2008 | BenQ P50
Can not open
You need to replace the joystick component; it is not caused by dirt. After some time it gets bad.
You need to go to the nearest authorized service center; that joystick is not a standard component, only the authorized service centers got them; taking it from another phone is not a good idea, doing it, the component will loose operability.
Jan 03, 2008 | BenQ P50
Can I upgrade BenQ P50's OS
@vikaslund
you have to double check your battery. i have a p50 and sometimes it does that. the problem is with the battery. if the battery doesn't charge, the orange light will remain as is. you might want to do the following steps.
1. remove the charger from your unit.
2. remove the battery and put it back it again after 10 seconds.
3. be sure to put the battery lock on its proper position
4. try to turn on the unit using the power button on.
5. reset the unit in it's reset button on the bottom.
if these five steps don't work, you have a dead battery.
buy a new one or have it repacked.
Nov 27, 2007 | BenQ P50
BenQ P50 internet connection problem
For access the internet through wi-fi connection  u need to do some setting on ur mobile .(like Access point etc). and if ur wifi hotspot is secured then u need to enter password or passkey while use internet
Gizmo1
Oct 21, 2007 | BenQ P50
How to repair my benq p50
pls do a hard reset and that will surely fix the probelem. pls refer to your manual.
Aug 07, 2007 | BenQ P50
jasbo
jasbo
