Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover Windtunnel model 6626 900 no suction - Hoover U6630-900 WindTunnel Bagless Upright Vacuum
  • 13 Answers
SOURCE: plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Posted on Dec 31, 2008
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
nwj2468
  • 76 Answers
SOURCE: Hoover 6446 900 WindTunnel Bagged Upright has
check for a clog in the brush hose
Posted on Aug 22, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
kevin_getz
  • 1031 Answers
SOURCE: My Hoover Dual V Windtunnel has suction but the
Take the lower plate off of the unit and check the belt for breakage. also, if it isn't broken, are there any obstructions between the belt and housing?
Posted on Jan 29, 2010
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The Hoover Windtunnel vacum will not pull suction
Either the machine or hose is blocked OR the filters are blocked.
Also possible that the belt is broken.
Please leave feedback
Thanks
Feb 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
22 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
