Question about Blodgett B36D-BBB Gas Kitchen Range
Leaving black soot on bottom of pots and pans
Is black soot on the bottom of pans normal? Does it need cleaning of the gas lines, regulator replacement? Any help would be great. Thanks
What can I do to prevent this stove from covering my pot with black soot every time I cook on it?
Make sure the pressure regulator located on the gas line is functioning correctly. If there's any orange color in the flame it's possible the regulator is malfunctioning. Another reason may be the gas/air mixture ring may be clogged with spilled matter covering it which would restrict the air entering the burner .
May 29, 2016 | Kitchen Ranges
How tp clean black soot off bottom of turkey pot
If you are cooking with propane or natural gas, you may need a new regulator for your range, the black soot is most likely too much gas being used to make the flame. But, as for the soot on the bottom of your pans, try letting the pan soak in a mixture of baking soda and water, then attack it with a brillo pad. Hope this helps!
Apr 10, 2012 | Kitchen Ranges
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
GE XL44 and soot from burners
propane burns very need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra Range
There is too much air in the mixture, close the air shutter on the burner a little.
Aug 17, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Blodgett B36D-BBB Gas Kitchen Range Logo
335 people viewed this question
Top Blodgett Kitchen Ranges Experts
Gil Shultz
ray gallant
Are you a Blodgett Kitchen Range Expert? Answer questions, earn points and help others
