Question about TOY 4 T-harness Remote Starter Wiring
Remote 4 keyless entry only work some times
The alarm is a viper system, and it was working fine,
over the last few weeks it has got worse, the car is a toyota soarer , the system locks, and unlocks the doors and the boot.5 times out of 10 it will lock the door but i can wate up to 5 mins trying to unlock it.i have replaced the battery in the remote.and checked all the wiring around the system . any help would b great, danny
  • Anonymous Mar 17, 2009
    I have the same problem. Which other wire needs to be pulsed?
    Scholar:
  • 116 Answers
Maybe this will help. ALL toyota's have a "child safety feature" on the door lock systm. You would never know it unless you lock the doors BEFORE you clse the driver door. At tht point, you woldn'y be able to unlock the doors using the factory wring as ther is ONE more wire hat needs to be pulsed upon unlock. Not to confuse you (I know, I already did). MAKE SURE that you close ALL the doors BEFORE you lock them and telkl me if it works then Than I can give you more support....cool?
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
I ordered a viper 3002, does it have a remote start and I'm just not seeing it?
The Viper 3002 is not a remote start system. It is only a security system with keyless entry. In order to remote start your vehicle with the 3002, you will need an add-on unit installed.
Dec 23, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Jul 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
Dec 02, 2008 | 791XV The 791XV is a 2-way Security and...
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
TOY 4 T-harness  Remote Starter Wiring Logo
425 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
