Question about HP OfficeJet 6210 All-In-One InkJet Printer
I have a hp officejet 6210 all-in-one printer. When I copy from the glass vs. the feed, I see thin, vertical, black lines running down the page.
    Scholar:
  • 97 Answers
clean the glass or try following steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
Black line going down page only when feeding paper through feeder
There should be a thin piece of glass to the left of the big glass that you put the original to be copied on. Clean the small glass very well and try copying again. If there is a spot on the glass, it will show up on the copy as a line.
Sep 06, 2013 | HP Officejet Pro 8600
Hp 6210 prints a black line down the center of the page. 1st 50 copies okay, then line started.
First diagnose if the line comes when using the doc feeder or the glass. If it only comes when using the doc feeder then you have a small dirt spot on the glass where the page is scanning over the exposure lamp. Just clean it.
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
When I copy using the automatic feed I get lines the full length of my page. When I put on glass it comes out ok. HP5610 all in one
clean the scan glass in the adf feeder its dirty or has white out or something on it. its a small **** glass where the paper feeds thru
Mar 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
When faxing on HP Office jet 6210 lines show up on the paper when it is recieved
Hi, The problem could be with the receiving machine and not yours. Here is a little test you can do, make a copy of a blank page and if the copy has line on it then it is your machine, if not then it is not yours. You need to open the top where the document feed through and clean the scanner glass with a moist rag, spots on that glass can cause lines.
Good luck, keep us posted.
Mar 13, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Black vertical line in scans and copies when fed through top document feeder.
clean your scan glass (thin strip of glass running from front to back, underneath document feeder) with a soft cloth and alcohol.
Jul 16, 2009 | HP Officejet 5780 Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
