Question about Epson R3000 InkJet Photo Printer
R3000 stuck in cancel mode but wont quit
I sent a job to the printer but then hit the Cancel button because i realized I did not load the correct paper. The Cancel Print window hangs and won't cancel the print nor let me escape out of the window. I was printing from Adobe Illustrator but I can't close or quit that either.
2 Suggested Answers
Basti
  • 1447 Answers
SOURCE: Won't print a 4 x 6 print. Paper passes right through printer
Hi-
Double check on printer properties under printers and faxes if 4X6 is selected, then access printer properties as well on the application or program where you are printing the images by clicking File then print option. Make sure Epson is the default printer.
Keep us posted, thanks!
Posted on Oct 29, 2008
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
Multiple print requests have been sent from laptop. They do not show in print jobs. They are no longer showing on laptop job list. It just keeps printing the unwanted jobs. Can I flush the memory of the...
Is there a cancel button on the Printer just keep hitting the cancel button till it quits printing, Also if you open the Devices And Printers Folder then right click on the printer you are having problems with then click see what is printing new window opens then in top left click printer then down and cancel all Documents.
Thumbs Up if this helped
Good Luck!!!
Jun 13, 2011 | Computers & Internet
I have a HP 4385 --how do you cancel a print job---it was sent a print job multiple times (over 10) from a Mac and i do not know how to cancel these jobs as they were sent in error and are huge ink...
The printer should have a stop/cancel buttom on the panel, just press that and it sould cancel the print job.
Also, you can delete the job queue from the computer. You should have a printer in the Dock, click on that and select jobs and click on the delete button. If you don't have the printer on the Dock, click on Apple, System Preferences and select Printers. Select your printer and click on Open Queue and delete the jobs from there.
Dec 02, 2010 | Office Equipment & Supplies
Card keeps jamming and ribbon breaks
Download the Fargo Diagnose Utility .
But Requires Windows 98, 2000, NT, XP, Me; 16MB of RAM (Recommended); SVGA Monitor (800x600 or higher is required); and at least one printer drivers installed.
If a card becomes jammed inside the printer, the LCD Display will indicate
approximately where it is jammed. At this point you can either try to correct the
problem and continue printing with the same card, or remove the card completely
and continue printing with a new card. Refer to the following steps for instructions
on doing either:
1. Leave the power ON, and open of the printer?s Top Covers.
2. Remove the ribbon and overlaminate as needed.
3. If you would like to try to correct the problem and continue printing with
the same card, do so by pressing the On/Cancel button to advance the card or
the Pause/Resume button to reverse the card. Use these buttons to help free the
card from its jam. Try not to move the card too far from where it was just
before the jam occurred. Once the jam is cleared, replace media, close the Top
Cover(s), and press the Pause/Resume button to resume printing.
4. If you would like to remove the jammed card completely, do so by using the
On/Cancel and Pause/Resume buttons to manually eject the card. Then,
replace media, close the Top Covers, and press the On/Cancel button. At this
point, the LCD Display will prompt you to either press the Pause/Resume
button or the On/Cancel button. Pressing the Pause/Resume button will cause
the printer to feed in a new card and reprint the job which originally jammed
along with all subsequent jobs still being sent. Pressing the On/Cancel button
will reboot the printer and cancel all jobs within the printer?s memory. In this
case, you must also cancel and resend the print jobs from your computer.
CLEARING A RIBBON OR OVERLAMINATE JAM
If the ribbon or overlaminate becomes stuck to a card or jammed inside the printer,
the LCD Display will indicate that it is jammed. Refer to the following steps to clear
the jam:
1. Leave the power ON, and open the printer?s Top Covers as necessary.
2. Remove the Take-Up core (the side with used ribbon or overlaminate on it)
from in between the two black Drive Hubs.
3. Steadily pull the ribbon or overlaminate free from where it is jammed. If stuck
to a card, pull the ribbon or overlaminate off the card and throw the card away.
If it is jammed underneath the rollers, press and hold down the printer?s
Pause/Resume button as you gently pull up on the ribbon or overlaminate. Do
not **** the ribbon or overlaminate to free it, since this will increase the chance
of breaking it. If it does happen to break, simply tape the broken end of the
supply roll directly onto the take-up roll. Then, wind a few inches worth of
ribbon or overlaminate from the supply roll onto the take-up roll. Be sure the
ribbon or overlaminate is passing beneath both the supply and take-up rolls.
4. Once the jam is cleared, replace media, close the Top Covers, and press the
On/Cancel button. At this point, the LCD Display will prompt you to either
press the Pause/Resume button or the On/Cancel button. Pressing the
Pause/Resume button will cause the printer to feed in a new card and reprint
the job which originally jammed along with all subsequent jobs still being sent.
Pressing the On/Cancel button will reboot the printer and cancel all jobs
within the printer?s memory. In this case, you must also cancel and resend the
H. CLEANING THE CARD FEED ROLLERS
To assure consistent printer operation, all of the gray card feed rollers within the
printer should be cleaned during every ribbon change (every 250 prints) or if the
rollers are noticeably dirty. To clean these rollers, use the special adhesive-backed
Cleaning Cards from the Printer Cleaning Kit. Refer to the following steps to run a
Cleaning Card through your printer:
1. Open the Top Covers and remove all print supplies from the printer. Leave the
printer power ON and the Top Covers open throughout this procedure. The
Cleaning Roller Assembly can also remain within the printer during this
cleaning process.
2. Remove the Cleaning Card?s adhesive backing paper.
Nov 12, 2010 | Fargo Pro L ID Thermal Printer
Card jams and ribbon keeps breaking
CLEANING THE INSIDE OF THE PRINTER
As you use your printer, dust and other foreign particles may accumulate inside
the printer?s case. These particles are attracted to the underside of the ribbon by
static produced during printing and can cause voids on the printed image.
Periodically, use the following procedure to remove dust and other foreign
particles:
1. Open the printer?s Top Covers.
2. Remove the ribbon and overlaminate from the printer.
3. Use a Cleaning Pad from the Printer Cleaning Kit or a soft, lint-free cloth
slightly moistened with isopropyl alcohol to wipe out all visible areas inside
the printer. Remove any debris that may be inside. Be extremely careful not to
let any alcohol drip inside the printer!
4. Once the cleaned areas are completely dry and free of foreign debris, re-install
the ribbon and overlaminate, and close the covers.
F. CLEARING A CARD JAM
on doing either:
Section 7: Maintenance 53
Pro-L Card Printer User?s Manual
G. CLEARING A RIBBON OR OVERLAMINATE JAM
the jam:
cleaning process.
Clear print job on Zebra printer
Simply press the PAUSE button then press CANCEL. If you have sent a batch of 500 labels, though, you will have to press CANCEL 500 times. I usually just turn the printer off, cancel the job in the printer driver status box, then wait for all of the error messages to pop up.
Feb 24, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
How do I cancel a print job sent to the Ricoh Aficio 2018D? It is no longer in my print queue, but printer is still printing all 480 pages
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
Jul 14, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Problem with printer
I had the same problem for quite some time, but then realized that I didn't fully close the door that covers the ink cartridges... closing that door firmly, then hitting cancel (orange button) did the trick.
Dec 29, 2008 | HP Office Equipment & Supplies
Blinking light
it means ther is a spool jobs that was sent to the printer, hit the cancel button on your printer and check also your pc for any queued job cancel all file and start again.
hope this helps
Aug 06, 2008 | Canon PIXMA iX4000 InkJet Photo Printer
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
Epson R3000 InkJet Photo Printer Logo
55 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
