Manual for Sylvania electric heater SOQC111
My heater works great, but it squeaks the whole time we have it on. Any idea on how to fix this?? Thanks.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: GE Electrical Water Heater Time Switch
Here is the guide to hookup you timer...
You will want the 240v instructions for a hot water heater. They are on pages 3 and 4
http://www.jascoproducts.com/timer/QuickStartGuide.pdf
Heatman101
Posted on Mar 01, 2010
I have a Bosch Powerstar Ae115 and the left cutout keeps tripping. It has worked great for 5 years. When i reset it, the water gets warm again(never hot as it was before). What could be causing it to trip?
Water leaking into elements. Bad PC board. Undersized breakers. Undersized main panel.
Bosch Powerstar is a computer that happens to heat water.
If your 5-year-old laptop computer was malfunctioning, you would not be surprised.
But for some reason (false marketing by manufacturers?), folks believe a tankless computer is going to last 20 years.
Moreover folks also believe tankless will provide endless hot water while saving money.
The whole idea of tankless saving money is a load of sales-BS that defies physics and common sense.
There are no service manuals... except bosch website has troubleshoot section in product manual.
Call a bosch-qualified service tech.
Go to Lowes and buy ordinary tank heater, and fix your heater today for only $250.
Tank-type electric water heater can be easily repaired and maintained by homeowner to last forever... that is a fact
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Jan 12, 2014 | Water Heaters
Little to no flow through unit
Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter located just above where water enters unit.
Copy following link for Bosch powerstar manuals with brief troubleshoot section in each;
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
Call service technician who is qualified to work on computer that heats water. For plumbing problems, call local plumber. These are two different things.
Fix any brand tankless yourself, same day, by replacing the whole thing. Buy electric water heater at Lowes for $285 and be up and running by sundown.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE9.5 Electric Tankless...
Water heater not working?
There is a suprising lack of information on those water heaters. Do you have any idea how old it is? Is it in a mobile home?
Apr 22, 2013 | Water Heaters
Sylvania electric stove heater, black (model SO111R-MBK) stopped working
Got a stove electric space heater But it will not trunk on just the flame button but no flames and no heat what can I do to fix this .boxes the remote control have to light up....Albert Gomez..2124 North Keeler ave..Chicago Illinois..60639...18722062470.....
Dec 08, 2012 | Sylvania Electric Stove Heater, Black...
I have a Bosch Powerstar AE125 where the left cut-out trips. This problem began at the end of last winter to the point I was resetting multiple times a week. During the entire summer I might have had to...
I suppose I would ascertain that the supply voltage is the same there as the outer cutout connectors. If equal, the breaker can be faulty. Worse case the heater has an intermittent short causing overload to trip out.
Fix It!
Nov 02, 2011 | Bosch PowerStar AE125 AE125 Whole House...
I have a goodman electric furnace. Model no AR32-1, where can I get a manual. My furnace is making a grinding/squeak noise. Is it okay to run it until it's fixed?
I'm not sure you have a true Electric Furnace or a Heat Pump, since both are electric.
In any event, Goodman has Owners manuals that you can download in a pdf format. Just look for your model #.
http://www.goodmanmfg.com/SearchResults/tabid/37/Default.aspx?Search=Owners+Manual
Feb 04, 2011 | Goodman Heating & Cooling
We had an electric heater plugged in and on for 6 min at the same time our microwave was on. The microwave stopped working but the heater continued to work. It is not the plug or the breaker so it must be...
Check the power fuser in back of unit. You'll need to take the screws out and open it up. If your not comfortable with this you may want to call a technician to come out.replacing that blown fuse will fix your problem. no need for you replace the whole oven.
Jan 21, 2011 | Whirlpool Microwave Ovens
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
