Question about Tappan TGF320 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
The stove was working fine until it was moved. The only thing done except for moving was a cleaning. The burners work and the pilot in the oven seems to be working also. The stove is about 20 years old.
  • 5 more comments
  • Russell Crawley Jul 21, 2007
    The stove is a Model M32-1026 and was built in 1077 so is is 30 years old instead of 20.
  • Anonymous Jun 05, 2008
    Do not know how to light the oven pilot.
  • geowns Jun 30, 2008
    Oven does not work. Has electronic ignition. No gas, no igniter. Get nothing but "ON" light when turned on. Product is Model 30 2761 00/04
  • Anonymous Sep 07, 2008
    pilot light is on secondary comes on but oven will not light
  • Anonymous Mar 13, 2014
    oven knob for tappan stove
  • Anonymous Mar 14, 2014
    This range is at least 40-50 years old. I like this stove but I fear it is becoming dangerous. It has two pilot lights - I am afraid to use half the burners because one of the pilot lights has gone out a couple of times and I didn't notice until the next morning. Now one of the other burners is not lighting all the way around (sometimes) and sputters. It either needs major cleaning out or replacement of parts. The building sent a repairman who threw up his hands and said it was old, so didn't do anything. Is it worth pursuing a repair job on this? Money is an issue as far as buying a good new stove goes and I'm happy with the way this cooks.
  • Anonymous Mar 28, 2014
    HOLDER FOR BURNER WAS OLREDY BURNAND GAS FLAME THROU THIS HOLE
  • 183 Answers
Probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
SOURCE:
Why does my oven does not work but top burners are good
Not sure but newer stoves have 4 wires 2 110 and 1 ground and 1 neutral. Older stoves had 2 110 and only 1 ground. The oven sometimes used the ground a sa neutral for little motors, displays, etc. make sure that the third wire on your plug has a good ground and see if that helps
Jul 16, 2014 | GE Stove / Oven / RanCooktop Assembly -...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
Delay in oven burner to light after pilot is lit.
Usually delayed lighting on a standing pilot system is caused by a gas pathway that is dirty from spilled food or grease. If you can remove the burner assembly and clean it that will correct the problem. If there is a removable plate above it then you can remove that and get access instead of removing it. Pilot ignitions work by creating a column of gas between the pilot and the burner that is established when the burner is turned on kind of like a fuse. A small tube my be used to establish the column of gas between burner and pilot and it may get blocked with food that overflows. Sometimes the pilot is just located right next to the burner and may get partially blocked or the orifice in the burner next to the pilot may be blocked. Cleaning all this helps. Be very careful with gas. Work in a well ventilated area. Turn on gas very briefly to run an ignition test. Turn off the gas and vent it off if it fails to light in about 5 seconds. Unburned propane drops to the floor and collects. Natural gas rises. Be aware of this when you ventilate.
Dec 23, 2008 | Magic Chef Ovens
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't heat
hi. thanks for the question. i would replace the igniter, on the oven burner.that will solve the problem. thanks the appliance doc
Sep 30, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at www.theoldapplianceclub.net. Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan TGF320 Gas Kitchen Range Logo
1,149 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
