Question about Braun WK200 Cordless Electric Kettle
I need a new base for my braun cordless kettle
2 Suggested Answers
SOURCE: My Braun electric kettle won't click on. Do I
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Posted on Mar 02, 2011
My kettle light is off and cannot heat
It has died Stephen! Get a new one - it will be cheaper than fixing this.
Jan 09, 2014 | Braun WK200 Electronic Water Kettle...
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
I have a model RK 17 Cordless electric jug kettle from cuisinart that I just love because of the old fashioned design. I need a new base because a mouse decided to chew the cord and was incinerated.
i HAVE THE BASE IT WORKED FINE, MY DAUGHTER COOKED THE KETTLE WHEN SHE TRIED TO HEAT IT ON THE ELEMENT, now I need to find a new kettle! ONSCHMITT@SHAW.CA
Jul 18, 2012 | Cuisinart RK-17 Cordless Electric Kettle
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
Switch became totally loose and cannot be turned ON
you havent specified where the switch becomes loose and inoperable .......it is in the plug point or the base of the unit
if it is on the mains then change the point
it it is on the base of the unit ...
then give some padding to the base where the plug is connected then
it will start working////////
i hope this suggestion will solve your problem
Jan 08, 2011 | Braun WK200 Electronic Water Kettle...
My Cuisinart electric tea kettle just stopped working - where can I get a new base? Model is discontinued CJK -17bc
I took the base apart an repaired the electrical connection. You need a special screwdriver to remove the 3 base screws. I took an old, cheap flat-head driver and filed a v-notch in the middle of the blade so it would work to remove the screws. Had to replace the connector because of corrosion. That fixed the problem for me.
Sep 18, 2010 | Cuisinart CJK-17BC Cordless Electric...
Shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
HOW DO YOU REMOVE ALL OF THE BROWN RESIDUE FROM A BRAUN WK200 KETTLE?
There are comercial products that will do this look for it in houseware stores, maybe some big Ace Hardware stores, maybe even at your chain grocery stores.
Feb 26, 2009 | Braun WK200 Electronic Water Kettle...
Braun WK200 Cordless Electric Kettle Logo
44 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
