Question about Merkury Innovations Audio Players & Recorders
How to take apart merkury metallic headphones
Need to take a part because something is loose and rattling inside
5 Suggested Answers
  • 1138 Answers
SOURCE: Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
Posted on May 13, 2009
  • 1525 Answers
SOURCE: I need help installing A Merkury Innovations
hello, i have a philips wireless head set and this how i set mine up, i take it you've got the sensor with long black wire attach to it this plugs into your earphone socket on your tv set then plug the power adaptor the sensor switch on make sure the sensor pointing towards you and put the batterys into the earphones and switch earphones on you should have sound get back to if you have trouble thanks
regards
shaun
Posted on Nov 28, 2010
  • 6771 Answers
SOURCE: There is a rattling noise
It is one of two things the speaker is defective "has a rattle" or it has come loose from it's mount, if you can remove the outer ear **** you should see two or three screws that hold the speaker in place, make sure they are tight. If the problem persists replace the headphones because it would be next to impossible to find a replacement speaker.
Posted on Feb 28, 2011
  • 46 Answers
SOURCE: There's a metal rattling in my right ear cup (like
You could take the headphone apart to see if something is touching the speaker - a small hair, for example, could've gotten past the protective grille and is causing strange noises each time the driver vibrates.
Hope that helps. Good luck! :)
Posted on Mar 02, 2011
What could be rattling inside the hand held shower head
It sounds like the flow restrictor may have come loose and be rattling around in their. There is no way to open that shower head that I am aware of. If it really bothers you, buy new one.
Oct 28, 2015 | Moen Home
Loose parts inside one headphone....?
The solution may be to open up the headphones and find out exactly what went wrong inside. It could be simply a loose or broken connection or something more serious related to that rattle.
Jan 14, 2015 | Skullcandy Skull Candy Hesh 2.0 Headphones...
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
Sdg109wf when running it like rattling sound coming out. what do i\I have to do?
You may have to find a way to identify the location of the sound; type of sound..metal on metal, like something is loose?
The only thing I know that rattles in a dryer is if something got into the baffles/the wings on the inside of the drum.
If this is the case you have to open the top of the drum and unscrew the one baffle that that has something loose in it.
Oct 18, 2013 | Dryers
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
There's a metal rattling in my right ear cup (like something is loose inside), is this fixable?
Mar 01, 2011 | AKG K-99 Headphones
There is a rattling noise in one side of my headphones. Like something has come off inside, is there anything i can do to fix it ?
Feb 27, 2011 | Wesc Golden Oboe Headphones
Loud rattle coming from the bottom of engine. mostly heard after letting off the gas, starting and shutting off the vehicle.
Very hard to know without actually hearing the vehicle but,,,With what you describe,the cat/converter 'may' be making the sound.With the car off and engine cool,get under and give the cat/con a really give shove or hit.The insides of them do corrode and the internals make a very loud rattle.If this isn't the problem it will let you see if there is a loose exhaust mount that may also make a rattle.(The cat/con sound is like there is a very loose metal plate hitting something)Its actually the internals of the cat. that have broken loose and rattling inside it.Hope this helps
Apr 09, 2010 | 1996 Jeep Cherokee Country
Receiver rattles. Like something loose inside.
The rattle is probably a weight. On purpose, they put a piece of metal in the handle part of the handset to give it more weight.
If there isn't a secret screw under anything in the handle, it's probably glued or clipped at each end. Those are the worst kind.
Sometimes a slight pressure at the break near the top of the receiver will be enough to seperate it to get a knife in the opening to pry it apart.
When you get the 1/3 part of it up, look to see if there isn't something else holding it. It may lead you to the tab or screw that does.
Before you destroy the handset, look under the receiver part on the inside. With any luck, there will be a part number. You'll need that when you order a new handset :-)
Carl
Mar 22, 2009 | BellSouth Lands Phones
How do i open the mbox 2 pro?
There are five shiny screws and one black one located behind the plastic front label (the part that has the markings for the input levels and switches), plus three behind the serial number label, inside the handle part you open with the allen key. This removes the front panel, then, there are about twelve screws around the plastic casing, attaching the casing to the inner metal encasing.
There are three screws behind the foam strip on the metal casing, which attach a heavy duty metal strip to the inner casing... the rest are obvious.
This is how to deconstruct the casing in the event that something is rattling inside.
Keep in mind, if you still have a warranty on your MBOX 2, you won't anymore once you deconstruct it. So I don't advise it unless your device is well past warranty.
Though, if something is indeed rattling inside, I'm sure that's a breach of warranty conditions anyway.
You had best check on that first, but you might end up taking her apart anyway.
Jan 05, 2009 | Digidesign Mbox 2 Barebone
Top Merkury Innovations Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Merkury Innovations Audio Player and Recorder Expert? Answer questions, earn points and help others
