Question about Toshiba Office Equipment & Supplies
Estduio 281c CB00 code - Toshiba Office Equipment & Supplies
What can i do for toshiba 281c is giving me error code c010?
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Apr 06, 2015 | Toshiba E-studio 281c Copier
Can I join a Toshiba 281c to a home group network?
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Feb 22, 2015 | Toshiba E-studio 281c Copier
Windows driver
my Toshiba studio 281c printer operates normally while running on windows xp through my LAN. When I try to print on it while running on windows 7, it will not respond, it does appear in the printer list?
Nov 08, 2013 | Toshiba E-studio 281c Copier
Replace heater lamp toshiba 281c
open side cover remove fuser kit and replace heat roll OR heat lamp
Nov 24, 2012 | Toshiba E-studio 281c Copier
Toshiba e-Studio 281C ADF not working
Make sure the ADF connector is plugged...
Feb 24, 2012 | Toshiba E-studio 281c Copier
I have a Toshiba 281c and a few days ago the display started acting up. Now when you power up the machine the display lights up but has no text or menus on it. You can't change the functions it is stuck on...
try to enter service mode by pressing 08+power on
enter code 1501 you will see 2 sighns "+" on display
by using plastic stick you can calibrate your display
just touch this "+" jently
then wait few seconds till calibrating process
Good luck!!!
Mar 13, 2011 | Toshiba E-studio 281c Copier
50 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
