Question about Pioneer Car Audio & Video
What amp for my pioneer 450w impp 12 inch - Pioneer Car Audio & Video
2 Suggested Answers
  • 32 Answers
SOURCE: pioneer 12'' impp
It could be that the sub is underpowered or that there is something wrong with the voice coil.
Posted on Jan 23, 2010
I am looking for 12"inch old styles IMPP with
best bet would be to check out an overstock speaker warehouse on web you ought to be able to find em at good price maybe check a discount warehouse also hope i was some help i also like those subs
Feb 22, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    What size of box in need Pioneer TS-W307D2 12
    Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
    Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
    Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
    May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
    I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
    I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
    Mar 12, 2010 | Sony Car Audio & Video
    Pioneer 12'' impp
    Jan 19, 2010 | Car Audio & Video
    Pioneer 4 way ts a6970 what are their wattage
    • 330W MAX.
    • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
    • IMPP composite cone woofer
    • Butyl rubber sound for smoother response
    • Glass-imide voice coil bobbin for higher power handling capabilities
    Oct 06, 2009 | Pioneer TS-A6970E Car Speaker
    How should I wire my 3 subs to the 500/1 amp???????
    First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
    Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
    Is it good
    If you are using a GM-7200 amp, it should sound great. Both the amp and the subs are rated at 800 watts so be careful not to overload the bass by turning them on full power. It is good practice to have a slightly lower watt amp than the subwoofers. If you can power your rear speakers from the amp, that would take away some power to prevent the subs from overloading. Overall, you should get a nice THUMP!!
    Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
    Car Audio & Video Logo
    444 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
