Question about Whirlpool LEB6200 Electric Dryer
Brown spots and streaks on clothes
I am getting brown streaks of varying sizes and browns "splotches" on most of my clothes when they come out of the dryer. Most of the time it will be on delicates and khakis. I am frustrated by this to no end. Any help would be appreciated. Thanks.
  • Jeff Nyahay Jul 28, 2007
    Thanks for the reply Noggin. I work alot and finally got around to work out some of the ideas you gave me. I know for a fact it isn't coming from the washing machine. The area around the dryer was pretty dirty so I cleaned it with my Rainbow vacuum. I installed a new vent. I cleaned the inside of the dryer using Barkeepers friend. There are no visible screws in the drum. There is a metal grate on the back of the inside of the dryer covering the heating element that had some stuff on it so I cleaned that. The most interesting thing was that there was brown stuff in between the drum and the back of the dryer. I cleaned that and everything seemed fine for about 2 loads and then it came back.
    Novelist:
  • 135 Answers
Something that happened to me years ago was almost exactly what you describe. Cleaned the inside of the dryer many times and couldn't figure out where the streaky marks were coming from. It wasn't until I stuck my head deep inside the drum and looked above and to the sides of the front door that I found the problem. Several chunks of nasty goo were hidden in that place I couldn't see when I cleaned the inside the inside of the dryer all those other times. Problem went away after I cleaned them off. Just had to find them first! Hope this helps. ;)
Posted on Aug 06, 2007
  • 944 Answers
Try a few test items, to make sure the streaks are not coming from your washer, rather than the dryer (a white cotton towel is probably the best, if you have one to spare, but try items similar to the problem ones). You could try taking an already marked item if it is ruined, circle all the existing marks with permanent marker, then use that. If definitely the dryer (try the washer test a couple of times) have a really good look inside the dryer at everything, check there is nothing that looks rusty - occasionally there can be a bad screw, bolt or part of the drum. If you see something, send us back a photo and we can talk you through what to do. If you are sure there is nothing visible, then first make absolutely sure everything you can get to is spotlessly clean. Get the vacuum cleaner in there everywhere you can from the front access door. Then pull the dryer out from it's position and check there is nothing nasty growing behind or under it that could be getting sucked in. Ensure the air intake is clear and clean. Check this link for info on how to clean your outlet duct - unusual, but sometimes mould or rodent activity can influence items in the dryer; http://www.doityourself.com/stry/stainindryer Check this link - there are many good posts describing ways of cleaning out different items from a dryer (try them if you think any could possibly be the problem); http://www.thriftyfun.com/tf690227.tip.html If you still get the same problem, then there will need to be some dismantling of the machine - probably not too complicated for someone who has basic tools and mechanical skills - is the dryer still under warranty? Please ask again if you have no result from the above, and we can try and talk you through it. Hope this helps :)
Posted on Jul 21, 2007
SOURCE:
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer leaves brown spots on clothing articles. Suspect back seals as gaps are evident and drum is loose within the unit. What is remedy? Cost of seal replacement?? Kenmore 62802 Electric Dryer Deb in Brown...
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Mar 23, 2009 | Kenmore Dryers
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Check an earlier post of mine. This problem was killing me and Whirlpool was of no help at all. They claimed to never have heard of these thin brown streaks. Well, it was the dryer and as proof, I found where the thin brown lines were coming from. The felt had worn out in one spot allowing thin, whites and other thin items to slide in between the drum and the backing, resulting in the transfer of a thin brown line randomly on my clothes. Replace the felt (rollers and bearings if necessary) and with the drum apart, clean off the burnt brown streak of the backing with Simple Green. No more problems.
Aug 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LEB6200 Electric Dryer Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
