Question about HP (D6021-63034) Fan Assembly
Cooling fan replacement for my hp 6624A dc power system
Need a cooling fan for HP 6624A DC power system
  • 56 Answers
TAKE 9VOLT BATTARY TO SEE WITCH WAY THE AIR BLOWS, UNLESS BY LOOKING AT THE POWER SUPPLY HOUSING AND UNDERSTANDY WHAT THE ARROWS ON THE CACE SHOWS DIRECTION,
DO YOU HAVE VOLT METER, YOU NEED TO TEST TO FIND OUT OUT WHAT 12VOLT + OR - IS ON THE POWER SUPPLY , SOMETIME FAN MANIFACTURE WILL GIVE A CABLE TO PLUG INTO YOUR POWER SUPPLY TO MAKE YOUR FAN TO OPERATE THE RIGHT WAY, IF YOU NEED MORE HELP WITH THIS YOU CAN CONTACT ME THREW THIS SITE
CANDYMANGANDY
Posted on Jan 27, 2009
I have problem of hp laserjet p4015printer 57.07error
This appears to be a fan disconnection or malfunction.
It will need to be serviced by an engineer who knows the internals and can open the printer without damage.
1 Verify that the connector J65 on the dc controller is firmly seated. 2 Listen for the fan to operate while the MFP is initializing. 3 If the fan does not operate during the initialization sequence, replace it. See Main fan (FN101) and reversing-unit fan (FN103)
HP RK2-0278-000CN Cooling Fan
MFG Part Number: RK2-0278-000CN Condition:Refurbished MFG:HP This HP RK2-0278-000CN is Genuine and works with the HP 4200, HP 4240, hp 4250, HP 4300, HP 4345, HP 4350, HP M4345, HP M4349 Printer series. Parts are thoroughly tested, inspected for damage & defects and guaranteed 100% fully functional.
Feb 06, 2016 | HP Office Equipment & Supplies
How do l clear error E57.01 on an HP 6040 MFP LaserJet printer
Measure the voltage between
connectors J103-4 and J103-6 on the
DC controller PCA right after the product
is turned on. If the voltage changes from
0V to approximately 24V, replace the
VOC fan. If replacing the fan did not work, then check the connectors on the DC controller, if they are seated then it is possible that the DC controller is bad.
Aug 07, 2015 | HP Office Equipment & Supplies
HP 8100 dn error code of 57.5 comes up, power cycle down does not fix the problem
HP LASER PRINTER 8100, 8150 ERROR 57.5 code
1. The fan 1 or the laser/scanner fan has occurred.
2. Replace fan 1
3. Replace the D.C. controller board.
Try reseating the connector to the fan, it may have worked loose.
May 18, 2012 | HP LaserJet 8100dn Printer
Hp 3005dn printer ,error 57.03
Quote from the service manual: "57.3 Power-supply-fan error.
Reseat connections to the specified fan and DC controller.
If the error persists, replace the specified fan.
If the error persists Replace the DC controller
May 31, 2011 | Office Equipment & Supplies
MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
57.4 Main fan error
Hi I hope this will help
The text come from the hp manual
good luck Ian
Q2431-90912 Chapter 7 Troubleshooting 287
57.X
PRINTER ERROR
To continue turn off then on
or
57.3
EP FAN FAILURE
or
57.4
MAIN FAN FAILURE
A printer fan is not functioning.
X Description
3 EP cartridge fan, right side
(LJ 4300 only)
4 Main cooling fan, left side
Turn the printer off and then on.
57.3 Cartridge fan error (F2)
1. Reconnect the connector
between the fan and the
DC controller PCA
(location J78).
2. Replace the fan. See "Cooling
fan (right side;
HP LaserJet 4300 series
printer only)" on page 170.
3. Replace the
DC controller PCA. See
"DC controller PCA" on
page 181.
57.4 Main fan error (F1)
power supply.
2. Verify that the ribbon cables
are fully seated in the
connectors on the
DC controller PCA.
3. Replace the fan. See "Main
cooling fan (left side)" on
page 168.
4. Replace the power supply.
See "Power supply" on
page 188.
5. Replace the
page 181.
57.7
DUPLEX FAN FAILURE
The cooling fan in the optional
duplexer is not functioning.
1. Turn the printer off and then
on.
2. Replace the duplexer.
Mar 25, 2011 | HP LaserJet 4250dtn Printer
HP 8150 error code of 57.5 comes up, I cycle power, I have checked all the cables and still comes up with error code. Does anyone have any suggestions?
Hi
Error code 57.5 in HP 8150 means that printer fan error has occurred with the power supply fan. This issue can also be due to laser/scanner fan. Make sure both the fans are working perfectly fine. If the fans are fine, then the error is due to DC controller board.
To resolve this error turn off the printer for 4-6 hours (atleast 4 hours), this will reset the error. However, even after 4 hours you still can see the error then please check and replace the fan1 (power supply fan). Also, check for any burnt components on the dc controller board.
Daniel Scott
Jun 18, 2010 | HP LaserJet 8150 Printer
HP 4000 with no power
I guess that you have a bad assembly to your printer after repairing, , try to check your printer assembly again, or simply replace the DC Controller if it was not a new one.
or contact me at
walid_sayed@hotmail.com
Mar 19, 2010 | HP LaserJet 4000n Printer
57.07 in HP laserjet 9040dn
57.07 - Delivery-fan (back) error (fan #3). Reseat connections to the specified fan and DC controller. If the error persists, replace the specified fan. If the error persists replace the DC controller.
Aug 06, 2009 | HP LaserJet 5200n Printer
Error 55.1 on hp 2600n printer
55.1 is a DC controller error. You want to make sure the printer is pluged into a good power source with no surge protector. The manual says to upgrade the firmware on the dc controller and if that doesn't work the dc controller would need to be replaced. You can get the dc controller firmware upgrade at www.hp.com. then click on software and driver downloads. then model type and operating system. Then look for DC controller firmware upgrade. Download and follow the instructions in the read me file in order for more instructions to load into the printer.
Jul 16, 2008 | Office Equipment & Supplies
HP (D6021-63034) Fan Assembly Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
