Question about Philips 42PF7320A 42 in. Plasma HDTV
Picture Problem The color is off very (red and greenish) and the picture has lines on it and is not clear. I have turned off the power and checked cable. Could you help me?
    Problem Solver:
I had a similar problem with an LCD monitor. I took the monitor apart and inspected the conponents, then reassembled it, and it worked. The problem may have been a loose connector inside the monitor.
Posted on Jul 20, 2007
Pioneer bdp 51fd picture color is green
check screen options. sometimes you can change the primary color's intensities(it looks stupid at 100% for all). You might have red a little low making yellow and blue show up greenish on the screen.
Oct 28, 2012 | Pioneer Televison & Video
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
Picture is greenish hue and cannot be changed from menu bar
The greenish hue cannot be adjusted from the menu. One has to do it from inside.First confirm by turning the color settings to zero using the remote. You should get a clean black and white image with no traces of any color ( inc: green ). If your TV is greenish , the green drive on the base of the picture tube has to be trimmed.
All you need is a screwdriver. There are dangerous voltages inside a TV, some as high as 27,000 volts !!!. Where the color adjustment has to be done there are voltages as high as 110 volts and 8000 volts.If you still want to make the adjustments yourself revert back for instructions
Apr 11, 2011 | Sony KV-36FS12 36" TV
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Picture with red 3-D effect
IC8001, STK392-560 seems defective, its convergence output IC.
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Philips 42PF7320A 42 in. Plasma HDTV Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
