Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
I have magicjack phone service how to get and send fax
Wat to download to make it work
  • ajkuglar Feb 05, 2009
    thanks for trying very helpful
    Genius:
  • 2,120 Answers
Fax machines are ANALOG, Magicjack is DIGITAL. Your fax machine won't work reliably.
Posted on Jan 28, 2009
Have a new computer will not work is not downloaded on new computer get dial tone but calls will not go through
Posted on Feb 09, 2009
I need to connect my fax whit the magicjack
A voice over Internet protocol device, magicJack allows you to make and receive telephone calls from your computer using a USB device. While magicJack does not officially support sending and receiving faxes, you can connect a regular fax machine to the magicJack device to send and receive faxes.
Attach the magicJack device to a USB port on your computer.
Connect the phone wire to the port at the end of the magicJack device.
Connect the other end of the phone wire to the "Input" jack on your fax machine.
Turn off error correction on your fax machine, and set your fax machine to the lowest possible transmission speed. Consult your fax machine's user guide if you do not know how to turn off the error correction or lower the transmission speed on your fax machine.
Send a fax to your magicJack phone number to receive a fax. You can find your magicJack phone number at the top of the magicJack splash screen that will display on your computer after inserting the magicJack device.
Send a fax from your magicJack by loading the fax you want to send into your fax machine and pressing the "Send" button.
Oct 31, 2016 | Computers & Internet
How to recieve fax without phone line
It should work fine.
Plug your fax machine into your magicJack, just as you would normally connect your fax machine to your telephone jack.
IMPORTANT!! If your magicJack is connected to your computer, make sure that "Normal (Hi-Speed)" is selected. Your fax machine will not work if you have selected "Air Card (3G)".
Jun 25, 2014 | magicjack.com
Can't send fax through magicjack
It is very unlikely that you will be able to send faxes through VOIP. All faxes have an analog fax card, and magick jack is a digital service, if you purchase a digital to analog filter that may work but is not supported by your fax machine. you can also attempt to change the fax speed to medium and error correction mode to off.
Al
Eliteprintersolutions@gmail.com
Jul 12, 2010 | Office Equipment & Supplies
I have a Cannon MX860 all in one machine. I have tried sending a fax multiple times with different baud rates down to 7200. The other machine answers and the two begin negotiation and the speaker goes...
its not the printer but magicjack. I have the mx860 its great but magicjack stopped supporting fax after an update came out. mine used to work great, but then just stopped after no change on my end
Jun 18, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
Fax on g85 w/magicjack (voip)
No, ALL fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line or Magic Jack.
Nov 05, 2009 | Office Equipment & Supplies
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
I have my fax machine hooked up through a magic jack. how do i change fax speed?
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | Brother Multi-Function Center MFC-240C...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
1,346 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
