Question about Panasonic Home Theater System System
How to connect Panasonic TV, DVD Recorder & Home Theater together
I have recently purchased Home Theater SC-PT460 and would like to link it with my TX-32LXD700 TV and DMR-EX87EB DVD Recorder. I have connected an HDMI cable from both the DVD Recorder and Home Theater to the TV. I have connected an optical digital audio cable from the Home Theater to the TV.
Q1. Is this correct? Do I need to run scart leads between all units or between Recorder/Theater in order to here surround sound when playing back from the Recorders Hard Drive?
Q2. If the cables are correct in the first instance, I do not seem to get any sound from the Theater speakers having followed the quick installation guide. Is there a simple solution to this problem?
  • 124 Answers
Missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Posted on Aug 15, 2009
How do i connect my sytem directly to the tv not just the dvd player?
Connect to the audio out of the TV, assuming you have a RCA audio out (red/white) on the TV. (Audio out of the TV to one of the Audio in of the SC-DT100)
The manual for the SC-DT100 is available from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/model.SC-DT100 .
Some new TVs only have digital audio out, this isn't compatible with this home theater system's inputs.
I hope this helps.
Mar 09, 2011 | Panasonic SC-DT100 System
I have a panasonic dvd home theater sound system SC-HT880 and i have just upgraded my tv from a Samsung 42 in Plasma to a Samsung 50 in 3D ready tv and i can not get the dvd payer to work in tv mode by...
Hi
Have you resolved this issue yet? I am in a similar position. recently upgraded my TV to a flat screen, also purchased a Blu-Ray but the SC-HT880 is now useless. How can I use the surround sound to work on TV? do I need to purchase an Amp?
Dec 31, 2010 | Panasonic SC-HT880 System
Unable to load DVD and mechanism makes noise like gears slipping
I think that ;
somehow someone bumped the unit and dislodged a DVD from the tray..
thus impeding the opening mechanism as well as the turntable (the unmeshing gears).
I would unplug the unit and remove the screws holding the top cover on , and take a look at the tray .
once thats done , let us know how this is going.
Aug 01, 2010 | Panasonic SC-PT460 Theater System
How do I change the regional coding on my Panasonic SC-PT460, I cant play half my library of movies. -Janus-
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Oct 12, 2009 | Panasonic SC-PT460 Theater System
Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Jul 12, 2009 | Panasonic Televison & Video
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Panasonic SC-PT460 - Little black box covers half of screen
Can you describe the 'box'? Is it the top half, bottom half, a little of either? What kind of TV do you have?
I suspect you might be noticing the aspect ratio of the various source programs being presented differently on a wide screen than you are used to. DVD programs come in a variety of aspect ratios. Normal TV is 4x3, that is, 4 units wide versus 3 units tall. Wide screens are more like 16x9, so a 4x3 image presented properly on a wide sceen would have black vertical bars on both sides. That is normal.
Some people are offended by the black bars and TV's are unfortunately designed to allow gross modification of the image to fill the space. That is akin to taking a photo of yourself and stretching it to fit an improper frame. That probably wouldn't be very flattering to you and certainly wouldn't be accurate. Which is more important - the picture or the frame?
Apr 08, 2009 | Panasonic Audio Players & Recorders
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
356 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
