Question about Toshiba Satellite C655-s5137 Laptop Intel Coretm I3-380m 4gb & 320gb
Usb prot drivers - Toshiba Satellite C655-s5137 Laptop Intel Coretm I3-380m 4gb & 320gb
  • Toshiba Master
  • 27,725 Answers
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Posted on Jan 22, 2013
Adding a brother printer to a hp2000 with 3 usb ports
USB ports create a virtual prot for USB-based printers, example; USB001, USB002, etc. It will not be LPT1.
May 13, 2014 | Lenovo H430-2558-1CU Desktop PC
Hii i have richo c2530 printer and i change my pc now when i conect the printer with lan port it gives yelow colouer in network even i conecet usb prot and when i print somthing it gives me eroor info...
Hello!
If you change the conections to the machine you need to change the port of the driver.
For exemple: If your machine is conected by TCP/IP you need to put the correct port in the driver properties.
If you conect to USB you need to chenge the port in the driver properties to the USB option.
If you have any doubt reply to me. I will be glad to help you
See you!
Sep 24, 2011 | Ricoh Aficio 2035 Copier
How to install officejet 4355 in windows7
First connect your officejet 4355 printer to computer's usb prot with usb cable.
Then download driver from below link if you haven't driver disk.
click here
Then install driver then you can use your printer in windows 7.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 02, 2010 | HP Officejet 4355 All-In-One InkJet...
I recently with to Windows 7 and I am having problems with the USB prots. Sometimes they work and most of the time they don't. Are their new drivers available to fix this problem? Any ideas????
There is no problem with your operating system which is the Windows 7. You encounter a hardware problem with your USB ports. It's not with the drivers. Your usb ports maybe defective. Buy an expansion usb card.
Oct 29, 2009 | Dell Latitude D800 Notebook
I cannot connect the hp psc 2175 to my computer
Check your usb cable works fine.
check your computer usb ports are works fine.
Try with usb prots 1 by 1.
Also uninstall driver then reinstall.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP PSC 2175 All-In-One InkJet Printer
When i am connecting my n72 with my pc a massege comes out that"USB device not recognized".my phone is showing the arrow like sign but my computer is not connecting with the phone...what should i do????
Remove Totally and Re-Install your Nokia PC Suite and Drivers first, then follow the On-Screen instructions to connect your Phone to your PC, at the same time, also try to use a different USB prot this time around.
Hope it helps.
Jul 10, 2009 | Nokia N72 Cellular Phone
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
Defective computer
Dear This Problem is fist time just formatt your pc
but fist your all data is backup in safe place anfter format you pc ..........way we have give this type fo solution ..........becuse we have fill this type of problem........ but on prot is not working and all other port is woking mise you usb prot is folty .......ok 100%........this Solution is working
any info login www.compudesk.in
Mar 28, 2009 | Averatec N270 1.6G 1GB 160GB 18.4IN DVD W...
Compatibility of parallel and usb
I have Canon LBP-800 laser printer with parallel prot and have computer with USB port.
I connect my LBP-800 printer with Parallel and USB Converter but printer is not functioning. I am using Windows XP.
Please solve the problem in details.
Thanks
ishaq
Dec 23, 2008 | Canon LBP 800 Laser Printer
Keyboard not working
Just buy a USB keyboard, that should work fine, it seems your PS2 port is faulty or its disabled in BIOS check there.
Nov 25, 2008 | Computers & Internet
Toshiba Satellite C655-s5137 Laptop Intel Coretm I3-380m 4gb & 320gb Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
