Question about Epson Stylus T10
Paper jams and would not feed
Paper will not feed an makes a loud grinding sound as if the "intake roller is stuck.
  • 826 Answers
Follow this link to get possible solution: https://h10025.www1.hp.com/ewfrf/wc/document?docname=bud04237&tmp_task=solveCategory&lc=en&dlc=fr&cc=us&product=58720
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Jan 22, 2013
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
Inky
  • 691 Answers
SOURCE: Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Posted on Nov 09, 2008
SOURCE: printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
Posted on May 02, 2009
asabur
  • 102 Answers
SOURCE: Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Posted on Jan 03, 2010
Testimonial: "many thanks for your reply - looks like is could be expensive (more expensive than replacing the printer?) i'll take it to an epson repair center"
SOURCE: I have a epson artisan 800 I'm tring to fax from
I took apart my artison 800 with 'paper jam' error and grinding noise. Sadly enough, it is the plastic gear attached to the stepper motor which is slipping and making the grinding noise. I tried to glue it and it worked once or twice and failed again. It is a design flaw and Epson should repair this for free if they are honest about this problem. Ir is not a user-caused problem.
Posted on Mar 31, 2010
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
My HP photosmart PSC2410 XI printer is showing "clear carriage jam"what should I do?
Points to there being paper stuck in the feed rollers, if you have cleared the jam, there may be a shred of paper still stuck, try to examine and remove.
If it IS fully clear and the indicatiors still show a paper jam, check the feed rollers are making contact with the paper, that the paper detector has not been bent upwards ( fooling the printer into thinking that there is still a jam).
Try rebooting the printer, if the problem still shows, this is a job for a qualfied technician
Mar 31, 2011 | HEWLETT-PACKARD PSC 1610 xi All-In-One...
I was in the process of making copies, when my Epson RX700 suddenly made a loud grinding noise. It then stopped working and displayed an error message: Scanner error occurred...Please see...
There are two drives in the printer. One moves the print head (cartridge) back and forth across the paper. Check to see if the "rubber band" drive belt is slipping or broken off. There is also a roller motor which feeds the paper. This has nylon gears which can make a grinding sound if one of the gears gets stuck. Make sure there are no pieces of paper stuck in the gears.
Mar 06, 2011 | Office Equipment & Supplies
Making loud noise ml1650 printer jam paper feed paper feed problem paper jam
Pull out a paper cassette and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Nov 21, 2010 | Samsung ML1650 Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
My E210 Laser printer makes a "clacking" sound. I think it may be the roller that feeds the paper. It happened after a paper jam when the paper got too low. Cannot print. Tried taking out the...
Look inside and check that there is n't any paper stuck in the rollers.
Take a very damp cloth and dab it with dish washing detergent. Clean all the rollers you see.
There is a seperator pad on the paper tray , clean it also.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 08, 2009 | Lexmark E210 Laser Printer
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
Copier jamming
One of your feed tires or rollers may have come off or be worn out. You may also have paper stuck behind one of the drawers, does it do this out of all the drawers?
Oct 23, 2008 | Canon imageRUNNER 210S Copier
Epson Stylus T10 Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
