Extra random number appearing on thleft of each transaction
Trnsactions are compted correctly but on the tape in front of each transaction a extra number appears and also on each z and x. Tried to restart the register as new but these numbers still appear.
    Sergeant:
  • 378 Answers
Try reprogramming
Posted on Jan 29, 2013
flexion1
  • 737 Answers
SOURCE: Royal Cash Register
Hi. There are several reasons for this.
The most common one is not replacing the ink roller on time. If the old roller had felt falling off of it, then it will block up the drum.
The second is re-inking the roller. If you do this, you end up with a sticky mess and a lot of smudging.
Other than that, pieces of paper stuck in the paper path are common.
You should inspect the drum again. This is the little group of rubber numbers that spin around and hit the paper while printing. You will usually find sticky muck on the numbers, and you may have to clean them several times. You need to turn the drum as you clean it. Try to use the gears at the side if they are visible. A dry Q-tip is best, as alcohol may damage the thin rubber. Try cleaning the drum again, and look for any improvement. If itgets better on some numbers, then you are probably on the right track. Also, if you could send me a picture of the bad print, that may help also.
Good luck.
Mark
Posted on Aug 09, 2008
SOURCE: I'm trying to open a
open it with screw drwier
Posted on Aug 19, 2008
sandrew
  • 2961 Answers
SOURCE: I want to register my
go here for product registration
Posted on Sep 07, 2008
Muggs01
  • 72 Answers
SOURCE: ke7yboard problem wi4th charac4ters-numbers
Check if the keyboard is plugged in all the way if it if try another keyboard.
Posted on Jan 16, 2009
  • 253 Answers
SOURCE: XE-A203 Cash register
unistall first and then reinstall it............and for more info contact http://tinyurl.com/m7ghqz
Posted on Jun 18, 2009
How to get 100000 in need for speed carbon
Cheat List:
Enter the following codes at the Main Menu for the desired effect: 1. Extra Money: Down, Up, Left, Down, Right, Up, X, B to get an extra $10,000 in Career mode. If you entered the code correctly, a message will appear.
2. Infinite nitrous: Left, Up, Left, Down, Left, Down, Right, X. If you entered the code correctly, a message will appear.
3. Infinite crew charge: Down, Up, Up, Right, Left, Left, Right, X. If you entered the code correctly, a message will appear.
4. Infinite SpeedBreaker: Down, Right, Right, Left, Right, Up, Down, X. If you entered the code correctly, a message will appear.
5. Need For Speed Carbon Logo Vinyls: Right, Up, Down, Up, Down, Left, Right, X to unlock the Need For Speed Carbon Logo Vinyls. If you entered the code correctly, a message will appear.
6. Need For Speed Carbon Special Logo Vinyls: Up, Up, Down, Down, Down, Down, Up, X to unlock the Need For Speed Carbon Special Logo Vinyls. If you entered the code correctly, a message will appear.
Sep 02, 2012 | Microsoft Xbox 360 Elite Console
How to get 100000 in nfs carbon
Cheat List:
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
Hello! I have a Sanyo VHR 120E video recorder. The trouble is that the tape remains and it does not add up! How can you make out of it?
Tape remain counters are never accurate. For one thing VCR tapes are made by different makers and some like to give you extra. Some counters allow around 5 minutes extra at the end of the tape. Treat all times as approx, then you can't go wrong.
Nov 19, 2010 | Sanyo Televison & Video
How do i generate random numbers on the casio fx-9860G
The random number generator function is called Ran# and can be accessed in RUN mode by pressing:
[OPTN] [F6] [F3] (PROB) [F4] to access the (Ran#) function
In the paragraph above, the bold text in square brackets indicates key presses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
The Ran# function generates a random decimal number between 0 and 1. If you need to generate a number with a higher range, then there may be extra steps involved. For example, to choose a random number between 0 and 100, you would enter:
Ran#×100 or Ran#(100)
Let's say you want to simulate a dice roll, where you get an integer between 1 and 6. Your first step would be to do:
Ran#×6
This will give you a random decimal number between 0 and 6. But we need an integer, not a decimal. To make it an integer, you would change this to:
Int(Ran#×6)
Press [OPTN] [F6] [F4] (NUM) [F2] to access the (Int)
This now gives you an integer between 0 and 5. We just need to add 1 to the result.
Int(Ran#×6)+1
The result should be an integer between 1 and 6.
Jul 06, 2010 | Casio CFX-9850G Plus Calculator
Generating radom itegers
In the paragraph above, the bold text in square brackets indicates keypresses, while the text in parentheses represents the menus that appear at the bottom of the calculator screen. This also assumes there are no menus on the bottom of the screen when you begin. If PROB is already on the screen, then the [F6] key is not necessary, just press [F3] then [F4] at this point.
Ran#×6
Int(Ran#×6)
Int(Ran#×6)+1
Mar 03, 2010 | Casio FX-9860G Graphic Calculator
Extra Long Receipts
we have Star TSP 700II and it is doing the same. not just 4inches but sometimes it adds extra 20-30 inches blank space. I think it was due to incorrect paper size settings.
Why dont you to go printer properties->Device settings and change the Friction size..as well as set Pagecut to Partial.
Also change preferences under Properties, advanced and change papersize to what suits you .
pl let me know what happens soon
sean
Feb 09, 2010 | Star Micronics TSP100 Thermal Printer
Keeps pumping out paper with no immage
Try and download the latest driver software from www.hp.com and install it. This is what it sound like to me, good luck
Feb 17, 2007 | HP LaserJet IIp plus Printer
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
