Question about AGA Kitchen Ranges
My economy 7 electric aga s red light flashes / comes on before economy 7 programmed times is it drawing down expensive electricity. It only used to do his if I did a dinner party now it happens every night.
  • 111 Answers
SOURCE: Turn oven on Red self cleaning light comes on
You oven latch handle is either bent or the switch that attaches to the last assembly is bad. More likely you have a bent latch. You can get to it after unplugging the range, lifting the cooktop up (3 or 4 screws under the front lip) then the panel under the cooktop has to be removed to see the latch.
Posted on Dec 23, 2008
  • 3 Answers
SOURCE: Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Posted on Jan 05, 2009
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
  • 4 Answers
SOURCE: Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Posted on Mar 12, 2009
  • 189 Answers
SOURCE: coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Posted on Apr 10, 2009
AGA electric oven will not heat up and Gill will not work even though orange light is on
The electronic igniter is not drawing the proper amperage to open the grill gas valve...
Jun 28, 2016 | Ovens
What is the problem with my mazda sting 160i 2002 model as soon as i use electrics like lights, wipers etc, the battery runs down. i've replaced battery, regulator and alternator 3 times already. It runs...
It sounds like something is drawing current 24 hours a day. When driving, the alternator keeps everything working. After you turn off the car, the battery is being drained by a short. The short can be anywhere, wiring harness, electrical connection points, etc. Have a mechanic check the current draw on the battery when the car is not running. It should draw a very small amount of current to keep the clock working. This will prove or disprove a electrical short. It is much harder to find the short. It can be expensive to fix if it takes hours to track down the problem. I would give the mechanic a time limit for diagnosing the problem to limit your out of pocket expense. There is nothing wrong with the battery or alternator. If they cannot find the problem within a reasonable amount of time. Trade in the car and buy another one. You do not want to spend thousands of dollars in repairs on a 12 year old car or a car with over 120,000 miles. I know you already put a lot of money in your car. Sometimes it is better to take your losses now than to keep putting more and more money into a car that is nearing the end of its useful life.
May 13, 2014 | Mazda Cars & Trucks
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
Have a 3 switch to heater light and fan. when i turn on heater with light on dim, flash/spark behind heater switch. is this normal
You have a triple switch that controls bathroom heat, fan, light combo.
When lights are off inside room, and you flip the heater switch, you see a flash of light inside the switch.
The switch is mounted in electrical box. If flash is inside the box where electric wires are, then that is NOT normal and should be looked after by checking connections and securing wire nuts.
http://waterheatertimer.org/How-to-twist-electric-wire.html
If the flash is inside the switch, then that can be normal. But it also might be time to replace switch if switch is old.
What happens inside a switch is that 2 brass connectors come together.
The amp draw from heater is large, so a lot of electricity suddenly passes across the brass connections and produces a flash of light.
If flash is accompanied by a sound, for example crackling or fizzing, and/or you smell electrical burning, then that indicates the switch needs to be replaced.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Broan-NuTone FAN CONTROL SWITCH
What does the number 7 mean
Economy 7 is a rip off, they are electric heaters which cost a fortune to run, they come on automatically after you set the dials on them, normally they store heat during the day and come on at night although you can change the settings,
It is not economy as stated you will simply pour money down the drain trying to keep warm.
You can put anything from £5.00 upwards on a key or card
Apr 30, 2011 | Washing Machines
What does it mean when the green light which comes on with the ignition flashes please? I have a Mayfair economy scooter but it is second hand and I have no user manual with it. The battery shows 3/4...
I AM A TECH FOR ELECTRIC MOBILITY # 1-800-MOBILITY
THE FLASHING LIGHT USUALLY MEANS LOW VOLTAGE AND THE BATTERIES ARE TOO LOW TO RUN THE SCOOTER. REPLACE THEM.
GOOD LUCK
TIM
Apr 29, 2011 | Electric Mobility 4 Wheel Power Electric...
I have a 7-DAY DIGITAL-IN-WALL TIMER model number #141224. I have tried calling you peopel at least 6 times, staying on the phone for as long as a hour, and I still cant get you. I am having...
A) Open following link to identify timer and download instructions.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
B) This timer is for single pole only and will not work for 3-way switching.
Timer does not have astronomical function.
C) If lights are blinking, timer is wired incorrectly.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
D) If you have trouble with programming, add a comment and say specifically where you are having problem for return comment.
I have programmed and tested this timer. Information above is accurate and tested.
E) Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Apr 14, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a utilitech 7 day in wall digital timer and would like to install it but have no clue how to. can you get me started
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
My nightstore electric aga has a red flashing light and is clicking , what is happening please ? Thanks in anticipation .
Just out of interest, did you work out what was wrong with your Aga, as ours is doing the same thing having been turned off for a month. We would be really interested to know what was the reason and the solution. Hoping its not too major. Many Thanks.
Apr 05, 2010 | AGA ALEG36-E-CD Electric Kitchen Range
Kitchen Ranges Logo
594 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
