Question about Pioneer PD-M603 6-Disc CD Changer
Pioneer pd-M430 laser lens fell out
The laser lens came out
3 Suggested Answers
SOURCE: IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Posted on Oct 14, 2007
Duncan
  • 218 Answers
SOURCE: Pioneer PD-M430
If you can't put it back then the laser unit is no good anyway so it may be worth a try. I would not recomend super glue because it outgasses a substance that may cloud the lens. (that is how they use super glue to get finger prints from objects) Maybe use a thin film (very thin film) of rubber cement very carefully applied to the edge of the lens would do the trick. You must act fast because rubber cement cures so very fast. Another possible glue would be epoxy. It would give you a little more time before it starts to set up. Be sure you have the correct side up when you attach the lens, and be SURE that it is well seated in its socket so that you don't screw up the focus of the laser. Do a dry run or two with no glue to get the feel of what it takes. Don't forget to clean the "inside" side of the lens before you glue it in. You can clean the outside once it is glued in place. If all else fails you still are in a situation where you have to change out the laser assembly. Nothing ventured, nothing gained. Good luck.
Posted on Jun 10, 2008
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
I have a pioneer model pd-m430 6-disc multi-playcd that won't play. it lights up when you turn it on but no sound. it some times channel through the discs but does not play
It sounds that the opticla pickup unit has the fault. Clean it and check. If this do not help you, replace it.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Jun 03, 2012 | Audio Players & Recorders
I have a Pioneer PD-M550 6-Disc changer. When I try to play a disc, it won't spin... UNLESS I turn the unit upside-down. Then it plays just fine. So the lens is fine, but something is keeping it from...
Hi. You need to replace the opu (optical pickup unt), laser in other words. The laser diode is slowly getting weaker and the lens works in conjuntion with the laser. The reason it works when it's upside down is because gravity is pulling the lens closer to the disc, thus it does not need as much power to focus onto the tracks etched into the disc. Replace opu with type PEA1030 aka PU-23 http://www.donberg.co.uk/catalogue/laser_units_cd_dvd/laser_pu_23.html. Hope this helps you out and good luck.
Mar 08, 2011 | Pioneer PD-M603 6-Disc CD Changer
I have a PD-M430 that has always worked and now it does not Is ther just a two wire hook up involved are am I missing something
your right just a left and right output to your reciever is all thats needed --of course the a/c power cord as well---if still no sound maybe your reciever settings have been set to turn off your cd jacks in favor of an optical input?!
Sep 04, 2010 | Pioneer PDM435
Have a pioneer cd player model number PD-Z560T. Has started making my cd's jump while i'm playing them.Have tryed cd lens laser cleaning disc but still no good any ideas?
My cd unit on the pioneer pd-z560t also jumps. I also tried lens cleaner, with no luck.
It was suggested to me that cleaner is only any good for a good - but dirty - lens, but no good if the lens has actually deteriorated and become weak.
I would be curious to know how a lens could actually deteriorate pls.
plese try to reply to: clerical@live.co.uk
Thanks
Andy
Nov 01, 2009 | Audio Players & Recorders
The 6-CD magazine will not eject from my Pioneer PD-M430 player. The 2nd-slot seems to be stuck. Is there any chance I can remedy this myself?
hello of course you can do it only you need a bit of precaution check this in magazine look for broken/deformed little piece of plastic especially in 2nd slot if it is ok next step look inside check again in the room where you put the magazine and it has a small coils check the 2nd i hope yu find the solution my best luck.........saludos
Nov 25, 2008 | Pioneer Audio Players & Recorders
Pioneer PD-M430
Jun 09, 2008 | Pioneer PD-M426 6-Disc CD Changer
Pioneer 6 disc PD-M455
Hello...if you can try to clean the laser lens whit a smooth cotton pin it may be dusty,,i have had the same problem...don't use any solvent just the pin very carefully,,,maybe you can use a mild solution made of hand dish solvent... and dry clean after...alternative use a cd.cleaning disc...Good luck Ron
Mar 10, 2008 | Audio Players & Recorders
Do not read CD.
lens fell out from the laser. blitz@rochester.rr.com
Oct 21, 2007 | Pioneer PD-M603 6-Disc CD Changer
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
Pioneer PD-M603 6-Disc CD Changer Logo
155 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
