Question about Lexmark X632 All-In-One Laser Printer
Lexmark x632 scanner error(046005 adf lamp failure)
Adf is not working or scanner
  • rosmed Feb 18, 2009
    tengo el error 046005 fallo de lampara adf. como lo soluciono.gracias
  • Ignacio Polack
    Ignacio Polack Apr 25, 2014
    Pudiste solucionar algo de eso? tengo 3 con el mismo problema
There can be a few causes of this error:
1) Firmware Revision is not latest and lamp warm-up time is too short - update firmware first:
http://support.lexmark.com//printerfirmware/
Type in: b103scan
2) Flatbed Lamp has failed and needs replacing.
3) ADF Optical Assembly has failed and needs replacing.
4) Most Common Cause:
ADF Optical Assembly Mirrors are dirty and need to be cleaned - Remove plastic cover from ADF and then remove ADF Optical Assembly. Remove the screw from one end and slide out the two mirrors - clean these and the mirror which is fixed.
Cheers Ross.
http://www.reboot.com.au
Posted on Aug 09, 2009
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Avision AV8350??? the error led is on, first time the led on & off For 8 number Sequence. then on for ever.
When you first turn the scanner back on, the READY light will blink, indicating that the diagnostics are in progress. If the Ready LED and Paper Jam LED blink 8 times, the error indication is "Light Check Fail (ADF)" or "Flatbed /ADF inverter check error".
Followings are the solution for the above problem:
1. Lamp is on? Yes. CCD error, Optical assembly is to be replaced.
2. Lamp is on? No. Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
3. Lamp is on? Yes. Issue resolved.
4. If the Lamp is still off, then Lamp is to be replaced.
5. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Jan 16, 2010 | Avision AV 8350 Flatbed Scanner
I am getting error code 843.01, what is the solution?
Found this information on the web. Hope it helps, because, Printer has been discontinued.
Problem
843 error; 843.01; 843.01 error; Scanner error; Scan error; Cannot scan; Will not scan Solution--Overview
An 843.01 error is generally caused by the Bottom ADF Cable on the scanner being loose or unplugged. Did the error return?
Yes: Continue to Contacting Lexmark
Items is Discontinue
Nov 16, 2009 | Lexmark C772dn Laser Printer
Fujitsu Scanpart 620c Leds error Amber on, Green blinking,red bli
Thank you for contacting Fixya.
You need to check the blinking times of the Paer jam LED. Then check the followings:
1. If the lamp is on, then ADF Switch is malfunctioning. Disble or short the switch.
2. If the lamp is off, then it is Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
5. If the Lamp is still off, then Lamp is to be replaced.
6. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Regards,
TechSatya
Mar 26, 2009 | Fujitsu ScanPartner 620C Flatbed Scanner
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Scanner replacement
I don't know how far you want to strip this, but if you're getting a scanner failure error, clean the underside of the scanner glass and the scanner mirrors then check all the connections (i've found this can cure the fault).
(1) Remove the ADF Rear Cover
(2) Remove 1 Screw from ADF cover
(3) Disconnect the Harness on the ADF PC Board
(4) Open the ADF.
(5) Release the Latch of the Left Hinge with a small
Straight Edge Screwdriver and remove the ADF.
(6) Remove the Control Panel Unit.
(7) Remove 8 Screws from scanner base
(8) Remove the Wire Clamp
(9) Remove the Scanner Cover Assembly
(10) Disconnect the Harness
(11) Remove 2 Screws
(12) Remove the Scanning Lamp
13) Slide the CCD Unit.
(14) Remove the CCD Harness Seal
(15) Remove 2 Screws
(16) Remove the Seal Plate
(17) Disconnect the Flat Harness
Note:
There is no need to disconnect the front FG
Harness that is attached to the CCD Unit.
(18) Remove 3 Screws and 2 Screws
(19) Remove the Main Board Cover
(20) Disconnect all the Harnesses.
(21) Remove 4 Screws
(22) Remove SPC PC Board
Jun 14, 2008 | Panasonic Panafax UF-9000 All-In-One Laser...
Error message: Check scanner unit E01-31
there are 2 ribbon cable that connects to the scanner lamp. The one closer to the front is the grounding cable. It connects to the metal plate by a ss plate. You can try fold a piece to fit between the ss plate and the ribbon cable to provide more pressure for the ribbon to the metal plate.
To access the ribbon, you need to take the ADF off by opening the document feeder cover, there is one screw that holds the ADF cover, unscrew that, and pil open the cover, then take the connector off, and then put up the document feeder, there is a lock in the back that u need to use a small screw drive to poke it to take the ADF off. Once the ADF is off, you can unscrew the 2 screws that holds the control panel, then disconnect the connector, then you can unscrew the screws around the glass and u can work on it.
Nov 01, 2007 | Panasonic DP190 All-In-One Laser Printer
Lexmark X632 All-In-One Laser Printer Logo
2,197 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
