Question about Samsung LN-R409D 40 in. LCD Television
LE32R8BDX Can anyone help me, I can't get PIP (Picture in Picture) to work. When I go into the menu, it is shaded out so can't access? Manual or website doesn't offer any suggestions.
  • Marko26 Jan 07, 2008
    I have the same problem with the PIP, but so far i read about this type of TV it says that it has only one TV tuner so PIP is not active with only 1 tuner u need 2 or more to have this option, i would try with the component plug ins like described below and ill write if that ones help.
Split your cable out of the wall twice. One will go to your cable box; ultimately going to box and out to hdmi cable. 2, from splitter, connect a second cable straight to the back of the tv and the pip will light up and then you can view two screens
Posted on Jan 26, 2008
My experience with an LE40R74BDX is that PIP is only available between the different input types of 1:- VGA, 2:- HDMI and 3:- everything else. It is not available between any 2 items in the everything else category. So you must have at least one of the other input types in use (I use HBMI for my cable box). Hope this reassures you, it's down to design not a fault.
Posted on Aug 19, 2007
SOURCE:
Vizio picture in picture
you can use the remote controller or the menu button in the tv panel. and then go to channel mode set up, select the PIP option.
Sep 15, 2012 | Televison & Video
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Mitsubishi CS-35301 has a rolling screen. Need to access service menu.
you need replace capacitors in vert.output circ. Not a service menu.
Jan 28, 2010 | Televison & Video
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Close Caption problem on Sylvania 6419tc
You are in PIP Picture in picture mode. Turn the PIP option off.
Feb 14, 2009 | Sylvania 6427TE 27" TV
Unable to access some menu options
maybe if you go to parental control and type in the code to unlock the v-chip , all other will unlock as well.
Aug 16, 2008 | Samsung HLP5085W 50" Rear Projection...
PC connection
Hi, Im having similar problems my new laptop runs on vista and wont display on tc, also tv menu blanks out pc mode & PIP not displayed. Temporary qick fix is to set uo older laptop xp to tv wait for the desktop screen to appear the swith then cable from the old laptop to the new on - like a boost. doing that allows me to have the laptop display on my tv and allow me to access menu, PC & PIP
Feb 07, 2008 | Samsung HP-P5091 50 in. Plasma Television
I can not get picture in picture off screen
if your sony don't have pip buttn. that tells your sony don't have pip board installed , i am afraid the pip comes out of the source you are getting the video signal sometimes your sat dvb dvd have pip in its menu check it out plz regards
May 02, 2007 | Sony KV-32S26 32" TV
Samsung LN-R409D 40 in. LCD Television Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
