Question about Dryers
Amana dryer, changing out the electrical plug from 3 to 4 prong
The plug is color coded and the dryer connection is not. Don't know where to connect the green, red, white and black wires.
  • 2 more comments
  • dswilson5197 Jan 27, 2009
    the screws and wires on the machine are not color coded and the ground is already connect from the circuit.
    And is the green the ground. I only have three screws where the old plug came off of.
  • dswilson5197 Jan 29, 2009
    Thank you. I will try to hook it up, but am still confused if I can connect the green (ground) on the cord to the ground on the machine and leave the ground off the circuit connected, meaning I would have both wires connected to the ground.
  • dswilson5197 Feb 03, 2009
    I can't thank you enough for the help. I got the cord on the dryer and everything is working good. I will highly recommend you to others should the need arise.
    Thanks again,
    Di
    Scholar:
  • 42 Answers
amana dryer, changing out the electrical plug from - 2116163639_1_-180x177.jpg
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Posted on Jan 27, 2009
  • Maintunivers Jan 29, 2009
    Yes; Green is the ground. White is the Neutral, Black is the "Hot / 110v" wire and Red is the "Hot / 110v" wire
  • Maintunivers Jan 30, 2009
    Above is a pic of a 3 wire set-up and a 4 wire setup going into the dryer. This should help you; did I fix ya?
    -C
    Fremont, CA
5 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
Greg20
  • 149 Answers
SOURCE: What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Posted on Jun 22, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
  • 8404 Answers
SOURCE: I am changing the 3 prong electric cord on my GE
ground the green wire to the frame of the drier.
trust me on this
Posted on Oct 16, 2009
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
I am going from a 4 prong to a 3 prong i do not have the manaul for the dryer and the 3 prong plug is not color coded there are 4 conectors and neutral on the dryer the 3 prong wire has 2 conectors and a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 02, 2010 | Roper REX4634KQ Electric Dryer
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
Change 4 plug out and put in 3 prong plugs it runs but no heat
The main difference between the 4-prong and 3-prong configuration is how the ground and neutral wires are connected at the terminal block.
The color codes are as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You simply match the corresponding colors with the wires present at the terminal block on the back of the dryer. In a 3-wire configuration, however, neutral and ground are connected together. This is done by connecting the ground wire from the equipment cabinet to the neutral wire at the terminal block.
In a 4-wire configuration these two wires are INDEPENDENT of each other and are not connected.
Please note that in homes built after the year 2000 it is REQUIRED to have a 4-wire configuration to be within the National Electrical Code.
If the wires at the terminal block are not color coded, Red and Black will be connected to the outer two terminals (left and right) of the terminal block, while neutral will be connected to the center terminal.
If you need more guidance, the following link explains:
If you have any questions, please let me know. I hope this helps you.
Aug 22, 2009 | Dryers
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
452 people viewed this question
Top Dryers Experts
