Question about Whirlpool LGQ8000JQ Gas Dryer
No Heat. I replaced the Thermal Cut out. Still the heat is not coming on. I cannot figure out any other reason why this problem continues. The dryer runs, blows air, tumbles, and turns on and off when it is supposed to, but it will not produce any heat. I have checked all the gas lines leading to it, but still nothing.
  • Whirlpool Master
  • 5,568 Answers
Sounds much like a failed igniter.  Most I've seen were surface heater devices (and all I've had to replace) which is a ceramic structure with a heating element on its surface that glows an angry red until the gas is ignited. Depending on the construction of the housing, these can be quite easy to replace. If you are in the US, check your white pages for "Johnstone Supply." They sell primarily to the 'trade' (appliance repair) but have never been turned down at the counter and the cost can be 1/3-1/2 of what dealers charge.
Posted on Jan 27, 2009
Tip
Whirlpool Dryer Various Test Procedures - Part 2
TEST #4 Heater
This test is performed when either of the following situations occur: Dryer does not heat Heat will not shut off
This test checks the components making up the heating circuit. The following items are part of this system:
Harness/connection, Heater relay, Thermal cut-off, Thermal fuse, High limit thermostat, Gas burner assembly,
Centrifugal switch, Exhaust thermistor, Machine control electronics, Gas supply. Dryer does not heat:
1. Unplug dryer or disconnect power.
2. Remove the back panel to access the thermal components.
3. Perform TEST #4b. If the thermal fuse is OK, go to step 4.
4. Perform TEST #4c. If the thermal cut-off is OK, go to step 5.
5. Locate the high limit thermostat. Measure the continuity through it by connecting the meter probes on the
red wire and blue wire terminals. If there is an open circuit, replace the high limit thermostat and thermal cutoff.
Otherwise, go to step 6.
6. Perform TEST #4d. If this is OK, replace the machine control electronics.
Heat will not shut off:
2. Access the machine control electronics, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (red-white wire) at the connector. If 5–15 k ohms are measured, replace the machine control electronics. If the resistance is greater than 20 k ohms, replace the exhaust thermistor.
TEST #4a Exhaust Thermistor
The machine control electronics monitors the exhaust temperature using the exhaust thermistor, and cycles the heater relay on and off to maintain the desired temperature. Begin with an empty dryer and a clean lint screen.
1. Plug in dryer or reconnect power.
2. Start the Timed Dry cycle.
3. If after 60 seconds, F-22 or F-23 flashes in the display and the dryer shuts off, the thermistor or wire harness is either open or shorted. Unplug dryer or disconnect power. Check wire connections at the machine control electronics and thermistor. If wire connections are OK, check exhaust thermistor resistance per step 5.
4. If F-22 or F-23 does not flash in the display, the connections to the thermistor are good. Therefore, check the exhaust temperature value at any or all of the temperature levels in question, using the Timed Dry cycle, and the following process: Hold a glass bulb thermometer capable of reading from 90° to 180°F (32° to 82°C)
in the center of the exhaust outlet. The correct exhaust temperatures are as follows:
TEMP
SETTING HEAT TURNS
OFF* HEAT TURNS
ON High 155° ± 5°F
(68°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Medium 140° ± 5°F
(60°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Low 125° ± 5°F
(52°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Extra Low 105° ± 5°F
(41°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature The measured overshoot using the glass
bulb thermometer in the exhaust outlet can
be 30°F (17°C) higher.
5. If the exhaust temperature is not within specified limits, or you have come here from step 3, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (redwhite wire) at the connector. If the resistance is OK, check P14-3 and P14-6 to machine ground. If resistance is greater than 0 (zero), replace wiring harness. NOTE: All thermistor resistance measurements must be made while dryer is
disconnected from power. The following table gives temperatures and ranges for the associated thermistor resistance values.
Temp
F C
Res
kΩ
Temp
F C
Res
kΩ
50° (10°) 19.0 -22.0 80° (27°) 8.5-10.5 60° (16°) 14.8-16.8 90° (32°) 6.8-8.8 70° (21°) 11.5-13.5 100° (38°) 5.0-7.0 If the thermistor resistance does not agree with table, replace the exhaust thermistor. If the thermistor resistance checks agree with the measurements in the table, replace the machine control electronics.
TEST #4b Thermal Fuse
The thermal fuse is wired in series with the dryer drive motor.
2. Access the thermal fuse by first removing the back panel.
3. Using an ohmmeter, check the continuity across the thermal fuse. If the ohmmeter indicates an open circuit,
replace the failed thermal fuse.
TEST #4c Thermal Cut-Off
If the dryer does not produce heat, check the status of the thermal cut-off.
2. Access the thermal cut-off by first removing the back panel. .
3. Using an ohmmeter, check the continuity across the thermal cut-off. If the ohmmeter indicates an open circuit,
replace the failed thermal cut-off and high limit thermostat. In addition, check for blocked or improper exhaust
system.
TEST #4d Gas Valve
2. Access the gas valve by removing the front panel and drum assembly.
3. Use an ohmmeter to determine if a gas valve coil has failed. Remove harness plugs. Measure resistance across terminals.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Samsung electric dryer keeps burning up thermal cut-off thermostat
I am not familiar with the model.
That the thermostat keeps failing, due presumably to overheated/burned contacts does indicate the element is drawing too much current. I can think of no other reason to explain your experience except possibly there is excessive arcing at the contacts as they open and close. The addition of a suppressor capacitor might help but the big question to be answered is why is there too much current or excessive arcing...
I can only suggest you thoroughly examine the heating element looking for breaks and accidental short circuits between the coils of the element or connecting wires.
Feb 28, 2017 | Dryers
Amana dryer not heating, replaced Thermal Cut off, High limit thermostat and Thermal Fuse, and new breakers in fuse panel
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
Dec 02, 2011 | Amana NED4500VQ Dryer
Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Feb 01, 2011 | Dryers
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
Dryers tumbles but there is no heat
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
No heat
check the thermal cut-off. it's on the element housing. when that goes out, the element will not heat up. good luck :) just check for continuity. it comes in a package with a new thermastat. replace both of them.
Jul 07, 2009 | Frigidaire FER641FS Electric Dryer
Whirlpool LGQ8000JQ Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
