Question about LG WM2688HWM TROMM SteamWasher
LG wm2688whm washer- when turned on - all the lights blink
When pushing the on button all the lights start blinking.
  • 745 Answers
SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Posted on Nov 27, 2007
  • 1294 Answers
SOURCE: Control panel lights up but washer will not run
Press "end of cycle" button to clear screen. Maybe your previous washer was here........drain pipe.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped.
Posted on Jan 04, 2008
MNTECH
  • 1543 Answers
SOURCE: my lg front load washer
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
e-Guru
  • 3917 Answers
SOURCE: washer will not spin after pressing the "play/start" button
There are a couple of reasons for the washing machine not to spin. Since the reason is not specific we need to to perform a couple of steps to determine the reason of the no spin.
Depending on the models the earlier models had brake shoes in the bottom of the machine. If you tip the machine over you can see them. If they are worn, they don't engage so may need replacing these were about 20 year old machines one of the problems with the newer models is that they have a cut out switch when you lift the lid if this is broken the machine wont engage in the spin cycle so it isn't an expensive part to replace that could be worth checking. A volt meter would quickly tell you if it was working or not it is just a basic switch the other problem that happens is that the pump is blocked i.e. some hair and may need cleaning. They stop if they are blocked. I think they have a sensor, but once unblocked they are fine. So that is a couple of ideas to start with.
Thank you for contacting Fixya.com
Posted on Aug 13, 2009
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Light blinking
click this link if you get any error or any light blinking on the pannel and the unit does nor works
http://www.applianceaid.com/frigidaire_frontload_washer5.html
thanks
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer spinsense buttom does not come on
I have the LG WM3988HWA, which is a washer and dryer in one. The way it works on ours is that you press and hold the Spinsense button for 3 seconds before you start a wash, or while a wash is paused. When Spinsense is on, the LCD will say "Spinsense" on the right-hand side when the machine is running. Nothing happens with the light on the Spinsense button.
Spinsense makes a huge difference as the machine is on the second floor of our old wooden house. I don't even notice the spin cycle with Spinsense on.
Problems:
1. We need to turn it on for every load. This is just annoying.
2. Spinsense will not turn on when you've the Dryer option activated. This means we have to do two trips to the machine for each load, or have our house feel like it's shaking to pieces. There's no good reason that the Spinsense/Dryer shouldn't work.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Jun 12, 2008 | Kenmore 4292x Front Load Washer
Dec 27, 2007 | LG WM-2277HW Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Spin speed
If that light is blinking, it's because the spinssense is turned on. If you look at the lighted buttons all the way on the top right of the machine, one of them says spinsense under it. While the machine is running, press and hold that button for 3 seconds. You'll hear a little chime and the light should stop blinking. It's supposed to help vibrations on wood floors.
Oct 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
48 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
