Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
Peerless 8700 cartridge - Peerless Industries Peerless& Single Handle Tub & Shower Faucet
Peerless faucet sometimes won't turn on
It sounds to me like the rubber o-rings are getting old. Try posting your concerns on the Peerless Customer Support webpage. They can help you identify the model of your faucet and what repair kit to purchase. (Repair is fairly easy, the faucet is repaired in-place).
Customer Support Peerless Faucet
Apr 16, 2014 | Peerless Industries Peerless& Single...
I have a single handle shower faucet, turn all the way and you get only hot water.... It has been dripping over the last few weeks when off, hot water. now it's a steady flow. How do I adjust...
hi there:) your problem is caused by the cartridge inside the valve body. could be one of 3 things...1)the cartridge is damaged 2)hard water build up 3)foreign matter. it is not to difficult to replace it yourself: first turn off the water then find the set screw, which holds the handle in place, usually located at the base of the handle and remove it. (look closely/carefully cause it's hiding) then remove the escutcheon ring and the trim sleeve to expose the "bonnet" (lock ring) and remove it. (ritey titey lefty loosey) now you can remove the cartridge and inspect it for debris/damage. if you need a new one just take it w/you to any plumbing supply including home depot and/or lowes and they will help you find it. here is the installation/owners manual from peerless: http://peerless-faucet.com/customer-support/find-repair-parts/documentation/P8760.html hope this helps but if you need anything else just ask:)
Jul 30, 2011 | Peerless Industries Peerless& Single...
How do you get a cartridge out of a Peerless 2 handle faucet?
if you are referring to a water filter that model does not have an internal filter
Feb 17, 2011 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Peerless faucet P99196 dripping; tried everything. Only made it drip more. How to fix?
If you have replaced boots and springs and or cartridges. Did you replace with after market parts or OEM. If after market parts were used use OEM. Hope this helps.
Apr 11, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Need to buy a peerless wall mount kitchen faucet P 99305 from :cathat3springs@hotmail.com...... need help!
Peerless happens to be a less than preferred brand. If you go to www.peerless.com, you will find the model type. Try it, you may be able to order it online. haven't seen it around.
good luck.
Oct 09, 2009 | Peerless Industries Peerless Wall Mount...
Peerless faucet with a squeeky hard to turn handle.
you can get a new cartridge for it or try pulling it out and putting some faucet grease on it the cartridge should come apart put grease on everything with a black o ring and you should be good to go
Jul 29, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Leakt fawcett
Depending on the brand there are sometimes "U" clips that slide from the top of the cartridge housing. Others have compression rings that you will need a special tool for. You can find the tool at your local hardware store. If you know the brand you can find a diagram on the internet to determine the type of retainer your faucet has. If I knew the brand I could be more precise.
Apr 20, 2009 | Peerless Industries Peerless& Single...
Instruction manuals
http://www.peerless-faucet.com/customersupport/requestliterature.html
Click on the link above and you can request the literature you are requesting. Peerless is made by Delta.
Mar 18, 2009 | Peerless Industries Peerless& Single...
I have a peerless tub diverter and I need to replace it because it leaks. Where can I find a replacement unit?
the kit to rebuild the peerless diverter is very common. take the cartridge to any hardware store and ask the plumbing clerk to assist you in getting the correct kit. good luck
Jan 19, 2009 | Peerless Industries Peerless& Single...
Shower temperature too hot
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Dec 10, 2008 | Peerless Industries Peerless& Single...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
67 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
