Question about Sharp AR-BC320 All-In-One Led Printer
Sharp ARBC 320 Error Code:F2-41
Not sure what this is, changed the Cyan cartridge, changed all the rest after the message didn't go away. Cleared the memory and rebooted the machine; the error is still there. Any suggestions?
  • Anonymous Feb 25, 2009
    I would also like to know the answer.
  • Sharp Expert
  • 316 Answers
Identification error
Posted on Jun 12, 2010
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
I have an error code F2-41
Your copier is starved for cyan toner. The cartridge either ran out or its' countdown chip went to zero without your copier alerting you that it was running low, sometimes that happens on those models. Change your cartridge.
Sep 28, 2010 | Sharp AR-BC320 All-In-One Led Printer
HP Laserjet 5550dtn printer is giving error 59.51, what will be the problem?
This code means there is a Cyan Cartridge motor error. The most common cause of this error is the Cyan Toner/Drum cartridge is binding up and causing the motor to stop turning. I would try removing then re-installing the Cyan cartridge first and see if it goes away. If not then replace the Cyan cartridge with a new cartridge. If the problem persists then there is a problem with the drive assembly for the Cyan cartridge.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | HP LaserJet 5550dtn Printer
Sharp arbc 320 error code tk how could i resset it
The counter for your mylar transfer belt has gone past 100,000. The belt has reached the end of its' rated life. You could clear the counter with Sim 24-4 but your copy and print quality will change. Eventually your belt will wear out, develop cracks and then split. There are rebuild kits for the belt unit or you can buy a whole new unit. Also the waste toner tank attached to your belt frame is probably filled up by now.
Aug 02, 2010 | Sharp AR-BC320 All-In-One Led Printer
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Sharp arbc 320 toner cartridge drive gear
Your probably going to need the parts manual to get the part number for it. The service manual won't have that information for you. can get that information you need for you as well and a lot faster than you get on here since that site is usually for copier technicians only.
Jul 29, 2008 | Sharp AR-BC320 All-In-One Led Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Sharp AR-BC320 All-In-One Led Printer Logo
419 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
