Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Condensation in my Whirlpool/Conquest refrig.
Whirlpool refrig and freezer has a lot of condenstion inside both compartments. What causes this. The settings are on the next to the last setting of each compartments.
  • Anonymous Mar 24, 2014
    condenser fan
    rattles
    condenser fan rattles
    Sniper:
  • 50 Answers
The refrigerator has a switch that says something like energy saver or something similar. move the dial or lever off the energy mode and that will bring on a low voltage strip heater around the frame of the unit. it may take a day or two to see results but if you place your hand on the plastic door liner you will see that it is warm and working. in the summer you need this on until the wreather gets cooler in areas where it's warm all winter you may have to keep it on allyear. what this does , when the heater is on it warms the plastic mouldings around the unit so there is not so much of a difference between the fridge/freezer and the room temperature. hope this helped
Posted on Jan 29, 2009
Side by side refrigerator not working but freezer is
Is the fan running inside the freezer compartment? Check for ice blocking the airway to the refrigerator compartment
Mar 17, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Nov 30, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Extremely hot panel between freezer and refrig sections
Usually is not a fire danger however there is a problem that needs attention. I would recommend that you call a qualified service man for this one as soon as possible.
Nov 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool rifreg.
I TAKE IT THAT YOU HAVE A WHIRLPOOL SIDE BY SIDE REFRIG.IF THATS THE CAUSE YOU NEED TO ESTABLISH IF THE FAN IN THE FREEZER IS BLOWING THE COLD AIR INTO THE FRIDGE.ALSO YOU NEED TO SEE IF THE DAMPER CONTROL IS FUNCTIONING CORRECTLY AS THAT CAN ALSO CAUSE IT.LASTLY IF THE FREEZER SIDE IS BLOCKED UP EITH ICE THAT INDICATES THAT THE SENSOR OR HEATER ELEMENT IS NOT FUNCTIONING;
LET ME NO IF YOU REQUIR FURTHER ASSISTANCE
GOOD LUCK
MOHAMED
Sep 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
