Question about Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore model number 110.28032701 and the UL light comes on 9 minutes, and we found oil and water underneath the machine
lenwest
  • 150 Answers
SOURCE: Kenmore Model 501-40002 Front Load Washing Machine
There is a flaw in the cycle (timer).Sometimes the manufacture will makes hundreds before they realize there faulty,sometimes they do this to create a demand for parts and service calls. You know what they say about lemons.You might have to replace the cycle controler.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 05, 2009
  • 11 Answers
SOURCE: Kenmore Series 80 Washer leaking oil underneath
TRY TO CHECK THE RUNNING CAPACITOR MAY BE THE OIL THAT YOU SAW CAME FROM THE DAMAGE CAPACTIOR.
Posted on Aug 21, 2009
SOURCE: my kenmore oasis shows the f1 upon starting the ma...
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
Posted on May 26, 2010
  • 744 Answers
SOURCE: In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Posted on Jul 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
UL error comes on. Leaking water on floor.
searching web I found this blog . hope it helps you figure it out Appliance Repair Forums
Aug 20, 2015 | Whirlpool WTW6400SW Cabrio Washer
Kenmore elite oasis washer will fill with water and skip the wash cycle. It will spin and empty then turn off. we have seen the code UL what can be done to fix this?
UL=Ultra Level of water?
usually its just foam in sensor tube,as prior using too much or wrong type of detergent(for hand wash,or else). Do few cycles with just and only water,or open machine and blow tubes to level "sensor".
Jan 24, 2015 | Kenmore Washing Machines
How do you solve the balance problem in the kenmore elite oasis even with no clothes it in
Try running with no clothes? If still shows UL when empty running, your machine needs service. P.S. use HE detergent or else.
Aug 27, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
The ul keeps coming whether it be one small sock or filled with bedsheets. I put a new pump on thinking the old was not pumping all the water out causing it to ul. Nothing has changed. Please advise
this is usually a main control circuit board problem...you can try and clear the board by unplugging washer and get access to board area.. unplug the touch pad and wait two minutes..now leaving touchpad off..plug washer in for tw minutes...now unplug the washer and install the touchpad and put together and plug washer back in...this should clear codes..if it works ok Great..if not, order main ccu board
Jan 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Having code ul
In most casest this indicates a problem with the software in the machines main control circuit board, replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456 also vist vist manage my life .com and ask for assistance in installing the board thanks
You can try to clear the Error Codes;
  • Unplug the washer for 1 to 2 minutes.
  • Disconnect the U.I. (touch pad).
  • Plug the washer back in for 1 to 2 minutes.
  • Unplug the washer.
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared.
Most of the time if no mechanical faults can be found the CCU (Central Control Unit) needs to be replaced. I would recommend running the diagnostic cycle first (see image below).
This is a very labor intensive do-it-yourself project, it involves extensive tear down of the washer. If you are not already sure you can perform these checks safely and competently, refer this work to a qualified professional. Working with live electrical current can be very hazardous and possibly deadly. Testing voltage output requires working with electrical current. Do not attempt these measurements without the proper tools and safeguards. First you will need to see if the washer gives that "UL" error while running the washer empty. Start a load with nothing in the washer. If the "UL" error comes up there is a mechanical issue or bad CCU. If the "UL" error does not come up there is most likely a loading issue. A common problem that causes a "UL" error is mechanical friction. I.e. something keeping the basket from moving as designed. You will need to remove the basket from the tub. I have included an illustrated set of instructions (See below). Check between the basket and tub for foreign objects such as socks or other small laundry articles.
Sep 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Model 110 top loading washer
May be the water pump! Give the model number in full.
Jun 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
