Question about NAD L40 CD Player
Cd drawer keeps opening and not saying closed
3 Suggested Answers
shanth
  • 108 Answers
SOURCE: CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Posted on Dec 22, 2007
SOURCE: NAD C521 CD Player
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Posted on Nov 08, 2009
How do I fix drawer on Azur 640 CD player?
Might be as simple as cleaning the lens
Aug 07, 2016 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Jul 20, 2010 | Philips Audio Players & Recorders
Cd drawer keeps opening and closing
Hi, Well i had the same problem with my CD drawer.Your CD drawer has some problem. Either repair it or buy a new one.
Thanks1 Sandy
Apr 21, 2009 | Gateway GT5220 PC Desktop
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Dec 21, 2007 | NAD L40 CD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Jul 16, 2007 | Teac GF-650 Turntable
NAD L40 CD Player Logo
26 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
