Question about Dryers
I have a Frigidaire AEQ6000ES2 electric dryer. It was working fine and then I moved maybe 40 miles away. When I got it in the new place it would not work. No lights on the front and no light when door open. Breaker was not tripped. I still reset it. I have 250 at the wall and through the cord into the dryer. All switches have continuity. Still no lights. Also there is power going into the board. So I replaced the board today and this thing still didn't work. How do you test the user interface board? Any suggestions would be great.
  • 23 Answers
SOURCE: Emachine T2958 will not turn on - has no power
Dear asksforhelp,
As u have told that u have change the power cord then the second thing u can try that check the SMPS is it working or not to check this u have to know that where is the SMPS where u pluged in the power cord in the cpu that thing is SMPS check wether the SMPS fan moving or not if no then u have to replace the SMPS if it is working then u have check wether the mother Board get the power supply or not check the 12 pin power connector insert it in mother Board if still it not working then it is definatly problem with u r Mother Board. So it is better for u that to go for New One.
Posted on Feb 13, 2008
  • 943 Answers
SOURCE: Admiral Capacity Plus Dryer won't
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Posted on Sep 22, 2008
SOURCE: Frigidaire Laundry Center (top load) dryer stopped working
dryer tub loose
Posted on Aug 23, 2009
  • 8220 Answers
SOURCE: Electric GE Dryer will not heat up
Posted on Sep 15, 2009
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
My dryer (Frigidaire Affinity)just stopped working as if the power shut off.. I have checked the breaker, it's fine. it stopped in the middle of a drying cycle. I'm thinking the control panel went out
Take a look at this web page/video. Your problem may be that the thermal limiter switch blew (which is not that easy to replace) .... compared to something in the control panel going out. Had you been doing a lot of heavy dryer loads before the unit died .. or a lot of lint built up? A blown limiter switch in some dryers will be as if you unplugged it (nothing goes on) ... but some dryers will still turn the drum but not heat. I am not sure about your unit.
The limiter switch is a safety device so your dryer does not overheat .... so if the switch did blow try to understand WHY .... or it may just blow again.
Good luck...
Jan 02, 2018 | Dryers
I can't remember ever seeing a light inside my dryer, but my husband thinks we need a new bulb.
Hello Michelle, thank you for your inquiry!
I understand that you are unsure if your Frigidaire dryer, AEQ6000ES2, has a light inside of it. I have researched your dryer and it does have a light inside of it. The part number for the light is 131843500. Unfortunately there are not instructions on how to replace the light. We would recommend contacting a professional technician for proper repair and replacement of the light bulb. I hope this information is helpful to you. -Matt
Dec 06, 2015 | Frigidaire Dryers
Why can't I get my new control board for my Frigidaire affinity dryer to work?
Hey tim bryant, thanks for your post!
I understand that you have installed a new board inside of your Frigidaire dryer, AEQ6000ES2, and on the new board the lights blink. I would recommend a reset on your appliance which can be done by disconnecting the power to it for roughly ten minutes. If that step does not correct the issue I would seek professional assistance for the repair of your dryer. I hope that is helpful. -Matt
Aug 13, 2014 | Frigidaire AEQ6000ES Electric Dryer
The belt is broken i have a new one i need to know how to get inside the dryer
Hi Cyndy s
Go to the following webpage and watch the video on how to dissassemble your Fridgidaire Affinity Dryer this is for the front slide replacement but you will remove the drum and you will see where the belt goes.
For parts and a schematic of your dryer.
If the belt is broken and you don't know how to route the belt check out the following picture
Please rate me
Oct 25, 2012 | Frigidaire Dryers
My dryer makes a clunk sound twice per each revolution. I thought maybe a bearing but all seems tight???
sounds like coins are in the tub vanes...take top off dryer and remove screws that hold vanes in place...maybe coins under the vanes....seen it hundreds of times in 40 years
Sep 18, 2011 | Frigidaire FEQ1442ES Electric Dryer
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
