One day I put a dvd in my computer and I noticed that the music was fine but somehow the voices were all muffled, it sounded like they were talking in a cellar somewhere far away. I have the same problem with my dvd-player that's connected to my TV but the problem only shows with one particular dvd.
At the moment none of the DVDs I put in the DVD-player of my computer have proper voices. Please help me.
The problem sounds like a setting miss match , with music it is not so noticeable as it is louder and has higher spectrum of sounds , but with monoliphic voices you pick out the disinction more check your sound utilities program particuarly the graphic equalizer if it has one windows does in sound properties and advanced setings if you have a seprate sound utility ie: hd sound etc check that your effects settings havent been changed ...Regards Vortash
Most voices come out of the centre channel. Put your ear to that to see if it is working. If it is not then you might have somehow managed to switch it off. Check the cable connections to the speaker also.
sounds like the speakers are out of order and/or maybe 1 or 2 not connected. use a AA battery and "pop" each speaker wire. it's low voltage and amperage so it won't damage your speakers. but the pop will allow you to know exactly what speaker you have and if it's connected. now make sure to put it in the correct spot. i would start with the center channel. sounds like this one's not connected. please rate if this was helpful!
Device phone was least manufacturer over impress user voice telecommunication however available means to improve impressions attained at alternate receiver device are discussable. First the telephone captures voice as delicate as is produce able. Attempt to produce voice with an impressive pronouncement to human voice to capture request expectation at alternate locate devices. Second, telephone voice is captured from an alternate device that has methods of improving audibility. For example, establishing telephone speaker devices that output audio makes imprssionful expectations, Also, computers that are attached telephony device has the capacity to capture displays to improve sound audio effects. Alternately, acquiring from retails telephones that have an improve voice functionality resolving audibility request. The telephone manufacturer makes innovativeness features as notice cancelling at backgrounds during telecommunication also among feature to regulate the volume feature to capture loud or reduced user expectations.
Hello, Please download Instruction Manual of DAV-DZ260 from Sony Support and go to page 25 and select appropriate sound option. The disc in player doesn't match with current sound selection thats why you hear muffled sound. Thank you.
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
It's an audio setting you will need to change. some movies are decoded in dolby and some by dts. This means you will have to adjust accordingly depending upon the source of audio in the movie. a double d is dolby's trademark and dts is regesterted trademark for the company "digital theater sound." The icons are on the dvd usually. Anyways, find the set up button on the remote control and use the directional arrow keys on the remote; up, down, left, or right to adjust for best sound. the thc5 will have the most function on the surround settings, movie, music, and all st. try a sequence, than repeat until desired sound is heard... good luck
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
