Question about Ricoh Aficio 1027 All-In-One Laser Printer
Paper drawer is stuck open
I received a mess. to add paper, opened drawer to add paper (no problem) can not close drawer.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Please pull out the tray.
Check if the rear end fence is out of place.
If so, please remove the metal plate with the spring, remove the gear in the middle of the tray (below the metal plate) and reposition correctly in its place the rear and front end fences.
Then try closing the tray.
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
Paper drawer stuck closed in imageclass d1150 how do I get into the printer
the drawer wouldn't open due to paper being stuck between the drawer and machine. ---www.doinggroup.com Email:market@doinggroup.com
Nov 29, 2013 | Canon imageCLASS D1150 All-In-One Laser...
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
KONICA MINOLTA magicolor 5430DL don't recognize paper
The machine keeps track of what paper was reqested last, and asks you to change paper if the new job is different. I get the "put media" message and have to open and close the drawer if my next print job requests a different paper. So I suggest you gently open and slam the drawer a couple of times, or see if you can find the sensor switch that monitors whether the drawer is open. Also check if your paper guides in the drawer are clicked in place.
Sep 03, 2009 | Konica Minolta magicolor 5430 DL Laser...
My cd/dvd drawer open or close. was stuck open. now has closed an
You may force eject the CD tray by inserting a paper clip inside the small slot or you may force restart your computer by pressing the power button for 5 seconds.
Jun 10, 2009 | Microsoft Windows Vista Ultimate Edition
Drawers wont open or close.
I will assume you are talking about the CD/DVD drive drawer.
Get a large paper clip. unbend it part way and use the straight end to push the drawer out using the little hole located on the front of your drive.
You may have a stuck disk in the drive.
Mar 19, 2009 | Dell Computers & Internet
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Jan 28, 2009 | Brother HL-4040CN Laser Printer
Paper drawer is stuck open?
there is a piece of paper stuck behind the paper drawer, remove the drawer and then look inside, also open side panel and you may be able to see part of the paper there also .
http://www.websitetoolbox.com/mb/copierquestions
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
2,298 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
