Question about Baby Care
The bright starts comfort and harmony swing stopped swinging. Music still works but won't swing.
SOURCE: i have a rainforest swing and everything on it
You can order the broken part and replace it. Call Fisher-price customer service and they will help you with that.
Posted on Jul 23, 2009
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
SOURCE: I have the Eddie Bauer
take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
Posted on Jan 04, 2011
  • 13 Answers
SOURCE: My 6 speed Graco swing will not work. The motor
It sounds like the problem is in the motor. Because of the heavy load on the motor during normal swing operation the brushes that are attached to the communicator are wearied out. This causes a loose contact between the brushes and communicator and the motor is loosing his power. Ideally, I would replace the motor. The only a problem is that the available replacement motors have a short shafts, when the motor used in Graco swing has a very long shaft. So, there are two solutions: buy a new motor sage from Graco for $28; OR buy a new motor ($5-$7), then carefully remove a nylon end cap from the old motor and replace it with the nylon cap from a new motor (WARNING: you have to be careful when doing this, because if it will be done inappropriately the brushes can be easily damaged)
Posted on Feb 11, 2011
  • 903 Answers
SOURCE: I bought the swing for my daughter and put new
It's likely the motor gone bad. The contacts inside the motor can get burnt out and prevent the motor from turning. Did you buy the swing brand new, or was it used? If you bought it new you should return it for a refund.
Posted on Mar 07, 2011
How can I fix a possible short in Bright Starts Ingenuity Cradle and Swing?
Sounds like a short n wiring. Was it plugged into wall outlet or running on batteries? Did u smell any burning? Or like warm, hot plastic? If it's ran on batteries or if it is a .wall plug, but there was no smell. U might b able to open it up and locate a lose, disconnected or old and or fauly wire. Which u could reconnect if still good. If faulty, then splice, replace, reconnect.That would b, if lucky. If your not and or it was a short, then it's likely to have burned up the motor, which is more likely if it was a wall plug.
Aug 08, 2015 | Baby Gear
Replacement parts for boppy travel swing 32891
Hi, you can purchase replacement parts on amazon, click here ant take a look: Orthodontic pacifiers for baby comfort safety. I hope this was helpful. Cheers
Apr 14, 2013 | Kids II Boppy Rock In Comfort Travel Swing
Comfort harmony swing wont swing
Is your swing still under guarantee? If so, you should take it back to the shop where you bought it or contact the manufacturer directly. When my baby swing broke, I took it to the local handyman and he was able to fix it for a very reasonable price. Good luck.
Feb 26, 2013 | Bright Starts Comfort & Harmony Duck...
Natures purest swing won't swing
I have the same problem. Works fine then next time I go to use it it won't work.
Feb 21, 2013 | Summer Infant 66010 Nature s Purest...
I ned a manual for the boppy rock in comfort travel swing. i am working off an apple computer and do not have a flash player
I cannot locate the manual on their website, links to it from elsewhere on the web show an error on their site. I recommending contacting the company:
Kids II, Inc. 555 North Point Center East Suite 600 Alpharetta, Georgia USA, 30022-8234 tel (770) 751-0442
Jul 24, 2011 | Kids II Boppy Rock In Comfort Travel Swing
The Bright stars swing is not working anymore. We put in 4 new D batteries but the swing does not have the same power? What can we do?
You'll probably need to replace the motor in the swing. Most of these types of swings work off a motor with a plastic gear attached, and the inside of the gear gets worn down over time. The motor still gets power and still turns the gear, but the gear doesn't have the grip that it used to so the swing doesn't move as much (especially with a baby in it).
Feb 04, 2011 | Kids II Bright Starts Travel Swing
Baby Care Logo
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
