Question about Ovens
Jes9900bas the clock works and a power loss sign
How do I set the timer on the EOG9330XN oven
If the oven is switched off on the wall or there is a loss of power, the clock will stop and you will not be able to use the oven. This also applies when you switch on oven for the first time.
Always you have first to set the time of day, then is possible to turn on the oven. Read user manual.
Dado
Oct 09, 2014 | Electrolux EOG9330 Gas Double Oven
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I have a stoves 720ef anf for no obvious reason the clock resets to 23.59 and the oven turns off, can you suggest anything
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
Nov 28, 2011 | Stoves 720EF Electric Double Oven
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
Panel says F5 and oven does not work
F5 = Watchdog and hardware conflict
Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
Sometimes just unplugging the sensor quick connect and cleaning the corrosion in it fixs the problem. Replace control board (also called ERC or clock).
F5 indicates the control felt a loss of power. I generally check the oven sensor for resistance (1040-1090 Ohms @ 770F). If the sensor is within normal limits, the control is bad.
Replace clock (ERC).
(see the following link) although it can sometimes be caused by a failed oven temperature sensor. The sensor should be checked before replacing the control. It should read about 1100 ohms when at room temperature.
- Kenmore 911.45565791 Electronic Control > www.appliance411.com/data.php?ap=AP3156070
- 911.45565791 Oven Sensor > www.appliance411.com/data.php?ap=AP2023670
Hope helps.
Jul 07, 2011 | Jenn-Air Electric Double Oven
We had a F5 code, how do we reset the control?
The F5 means Loss of relay drive circuit . If this fault code cannot be cancelled ( You can canselled it by remove the power plug for one hour and then power on again),If the it is not canseled then replace the oven control (also called clock or ERC).
Nov 25, 2010 | GE Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
Having trouble with the clock display
try holding down clock button.. when you 1st hold it down it will appear.. keep holding til it disappear.. then when it comes back on let go of button.. if clock button don't try another like + or - sign.. good luck.. mike
Jan 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
