Question about Canon MV960 Mini DV Digital Camcorder
Camcorder will not connect to PC
My Canon MV960 will not connect to my PC, this is my second camera within 6 months. I have a firewire port installed on PC (Win xp)and all correct connectionn cables. PC has been checked by manufacturer and firewire port is working properly. Camera's did work initially as I have downloaded some video from camera. But now unable to connect. Can connect using USB ports and save video from multimedia card but quality very poor. Please, has anyone had this problem or is there an ongoing fault with this video camera's DV port?
  • 1 more comment
  • Managhan Feb 15, 2009
    I have exactly the sam eproblem! Tried a friends Canon camera (slightly older model) and it worked just fine. I have tried new Firewire cables and card to no avail.
  • babrown115 Feb 17, 2009
    I have exactly the same problem, The firewire connection recently failed on both my DVD recorder and PC. Although I purchased camcorder almost two years ago I have not until recently used it very much. I now have to resort to using the AV connection instead of the firewire one which is ok for the DVD recorder but not for the PC as the relies on a firewire connection. I am thinking of contacting Canon (020 7724 7622) Customer care to seeif they can help. It seems to me that there could be an inherent fault with this particular camcorder and if this could be proved it is possible Canon would be obligated to either repair or replace it free of charge under The Sale of Goods Act.
  • upohar Mar 17, 2009
    After connecting thru' firewire just fine for about 6 months, my Canon DV960 suddenly became undetectable by my PC. I have so far tried to connect using 3 different PCs without any success. I would be immensely grateful for any solution to this problem ?
5 Suggested Answers
SOURCE: JVC GR-D73 DV CAMCORDER
Link download:
http://uk.jvc-service.net/public/document.cfm?prog=ProdSoft.cfm&Model=GR-D73
Posted on Jun 25, 2008
SOURCE: PC does not see camcorder when connected via firewire port
apparently I get wind from researching this issue that it's not the camera, it's not the cable, it's not your computers' hardware, that this is an issue with windows directly. I have the same camera and several other systems with 1394 (firewire) ports, and this camera used to work when I had windows xp service pack 1.
Posted on Sep 26, 2008
  • 435 Answers
SOURCE: Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Posted on Mar 10, 2009
old marine
  • 2237 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
I have a Canon 7.4V video camera and want to connect my camera to the computer. How do I do that?
Instructions:
  1. Connect an i.LINK (firewire) cable (also known as IEEE 1394) to the i.LINK port on the digital camcorder.
  2. Connect the other end of the i.LINK cable to the computer. NOTE: The computer i.LINK ports and capture cards may have either 4-pin or 6-pin connections. If your computer only has a 6-pin i.LINK port, then it will be necessary to use a 4-pin to 6-pin i.LINK cable.
  3. Turn on the digital camcorder by moving the POWER switch to the VTR position.
  4. Cue the camcorder tape to the beginning of the video footage.
  5. Turn on the computer. Your computer should recognize your camcorder and automatically install the needed driver.
  6. Start the video capture software on the computer.
  7. Begin playing the recorded video in the camcorder.
  8. Begin importing the video with the capture software. It should now be possible to copy the video using the video capture software if the computer hardware and software are configured correctly.
Hope this has helped you.
www.austintelstarservices.com
Sep 04, 2010 | Canon Video Cameras
Hello, I recently shot a student film on a Canon HV20 HDV Camcorder, Problem is my school doesn't have an HD deck to allow log and capture. I have final cut 6 and still can't get the setting right to...
This camera works fine with FCP 6. I use it all the time. You need to use the Easy Setup for Firewire basic HDV 1080/60i (or whatever sounds like that). The camera should be connected from it's small connector FIREWIRE port(under back panel cover -- USB port will not work for this use) to either a Firewire 400 or Firewire 800 port (auto-switches to 400Mbps if the device doesn't support 800) on the computer. Cables are available with a variety of connectors for this for under $20 ea (it's digital -- i.e. don't overspend on cables unless you have an actual problem!).
Mar 13, 2010 | Canon HV20 HDV Digital Camcorder
No images
Download Itune player to view videos
Feb 27, 2010 | Canon MV960 Mini DV Digital Camcorder
Aug 21, 2009 | Canon ZR500 Mini DV Digital Camcorder
Pc instollation of my camcorder
1. install the cd driver camed with your camcorder
2. use USB cable to recognize your camcorder to be use on your computer.
thats it! hope that helps!
CHARCOIS
Sep 13, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Jun 09, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon driver
hello pratt123
try here for the driver Canon Australia - MV960
riz.
May 01, 2008 | Canon MV960 Mini DV Digital Camcorder
Mv960 have no manual missed place it
hello waynerock
hi you can get the manual and other stuff from here .
riz.
Feb 19, 2008 | Canon MV960 Mini DV Digital Camcorder
Canon ZR800 MimiDV Camcorder
You cannot connect a DV cable to a USB port. These are two incompatible standards. DV is also called Firewire, iLink or IEEE1394. You PC must have that kind of port for you to transfer your video from the ZR800 and you will need a DV (iLink/Firewire) cable. You cannot use USB cable they will not work. Check www.MyCableMart.com if you want an example. Most new PC come with 1 or 2 iLink/Firewire/1394 port. If you PC does not have an iLink/Firewire/1394 port then you will need to install a iLink/Firewire/1394 card (see http://www.usbfirewire.com/Parts/rr-fw-byt.html) for more information.
Aug 13, 2007 | Canon ZR800 Mini DV Digital Camcorder
Canon MV960 Mini DV Digital Camcorder Logo
139 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
