Question about Home Security
My genie GICTD is not opening the garage door after I change the battery ...it might work a couple of times and then doesn't
glenmann62
  • 91 Answers
SOURCE: Garage door opener won't work
you should have installed a emergency key release !, it,s a cylinder that you put a key into and pull out a cable thats attached to your emergency release inside the garage , right now you would have been in already , but since you never installed one lets deal with the problem at hand , answer me this : do you have power inside the garage ,are you certain that the breaker is on ,did you have any recent power failures ?, because the circuit board on your machine could be fried from a close lightning stike , and i,ve seen it a thousand times , also your capacitor on your machine may be shot ! is your door wood or steel? if its wood drill out a 3 inch hole saw hole on the top panel either to the left or right of the center wooden cross member , now get a flashlight and look for a emergency relese rope , after you have located it,make yourself a coathanger with a hook at the end ,tug at the rope until your able to pull at the handle thats attached to the rope once you are able to release the door from the carriage assembly keep pressure on the handle and have someone else lift the door and when you want to fix the hole you made just simply glue the circle cutout back in place , good luck and do what i say to get in , please leave a nice rating if i was able to help you ,sincerely glenn
Posted on Mar 06, 2009
rustym62
  • 201 Answers
SOURCE: My garage door opener remote range limitted
Yes the receiver can go bad over time and lose range. Most likely the receiver cost plus the labor will cost as much or more than a new unit...depending on who does the repair. FYI another cause of reduced remote range can be signal interference from other sources which would be a little harder to track down unfortunately. Wireless routers, new appliances anything with electronics are a possible source of trouble.If you or a neighbor bought any new gadgets there's a small possibility of thatbeing the issue. But based on the age of the unit that's my first guess.
Rustym62
Posted on Apr 30, 2009
dburns60
  • 410 Answers
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
  • 31 Answers
SOURCE: Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Posted on Aug 26, 2009
  • 68 Answers
SOURCE: genie remotes stopped working
Yes RF units can go bad, especially older ones, the best thing to do would be to get a whole new opener. i say this because if one thing has gone bad that it is only a matter of time before another goes bad
Posted on Oct 25, 2009
Genie garage door opener gictd won't close
if you can hear the motoring running and nothing is moving then it is possible the internal gears are stripped. if motor does not run then it could be several electrical issues.
Mar 07, 2015 | Building Materials
Garage doors opens on its own, after being close for hours
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Apr 05, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Can Genie Wireless Keypad work for door w/o LEARN button?
If the keypad doesn't have dip switches it will not work with that opener.
Jun 29, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a genie pro max PMX 300 IC/A garage door opener and bought a Genie 3-button remote (model G3T-R) and I can't get it programmed. I push the button on the back of the opener, push the button
Take the opener apart and see if there are about 4 numbers that can be set. If you have an older remote take it apart and match the numbers, then program it.
Feb 07, 2012 | Home Security
I need KLIK2 remote instructions
How do I connect KLIK2 to a linear with a learn button
Feb 17, 2010 | Universal Garage Wireless Keyless Entry...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
Home Security Logo
37 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
