NEED UNIVERSAL REMOTE CODE FOR SHARP 27F641
I BROKE THE ORIGINAL REMOTE AND WOULD LIKE TO USE A UNIVERSAL ONE BUT THE SHARP CODES LISTED FOR THE MOTOROLA DRC400/425 SERIES REMOTE CONTROL DON'T WORK.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Setup codes to Sharp Brand TVs with GE universal remote control are: 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122.
If you wish to get more codes and other details to many remote controls, check this site. It has details about setup codes and setup proceedings to remote controls. Check them, and find out which brand remote control has codes for Sharp TVs, and buy one according to the availability. Code list and setup proceedings to the remote control will be accompany with it. Never forget to collect it.
Posted on Jan 22, 2013
mewms_14904
  • 1027 Answers
SOURCE: remote code list
JVC DVD 0558 0623
Motorola Cable 0476 1106 0276 0810
Posted on Mar 06, 2008
aprmaejun
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
Posted on Jun 15, 2009
  • 176 Answers
SOURCE: Remote Codes for Motorola Cable Box DCT700/US
I have run into this problem with my Sharp Aquos as well. This is not necessarily a code problem but an interference problem.
If you take your hand or a thick book and sort of make a hood over the area of the sensor on the cable box and place the remote right up close to the sensor this will help let you know if the remote and the box are working with the code. Also might try turning off the TV or unplug the TV to test and make sure the remote will turn on the box.
Next thing after you determine this is how to block the interference and be able to use your remote. What we did is placed the Wii on top of the box over the area of the sensor and this seems to have done pretty good.
Good Luck ....
Posted on Jan 09, 2010
Change inputs on sharp tv 13VIN100 without original remote
Without its original remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
https://homenol.blogspot.com/
https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts. /
Apr 22, 2018 | Sharp Televison & Video
Codes for sharp tv on a rm700 universal remote
Use code search. If a search through all codes stored in the remote control fails, you may have to try a different one. All universal remote controls do not store all possible codes.
Oct 02, 2017 | Sharp Televison & Video
I need a remote for the sharp cd-mpx850. I can't change the station.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 14, 2016 | Sharp Audio Players & Recorders
What is the code for sharp tv?
Hi Ken, the codes are from the link at the bottom of the list...... CHEERS..
The 3 digit codes for most programmable universal remote controls for Sharp televisions are:
002
013
014
111
502
509
712
812
813
913
918
NOTE: Codes to operate televisions using a Sharp brand universal remote control will be 2 digits long. They will go from 01 to 18.
The 4 digit codes for most programmable universal remote controls for Sharp televisions are:
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
If these codes do not work or you have other codes that work, please leave a comment below.
Remote Control Codes For Sharp TVs Codes For Universal Remotes
May 01, 2016 | Sharp Televison & Video
Como desbloquear mi televisor marca sharp xflat stil?? No tengo control... se puede hacer sin el control original?
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Jan 12, 2016 | Sharp Televison & Video
Need help programin my sharp remote too my zenith
0456 0475. These are the codes to check with Zenith brand TVs. If the Sharp remote control have these set-up codes in its memory, you can. Otherwise, you have to buy an other remote control. If you wish to buy its original remote control, contact the authorized service centre for Zenith, or authorized dealer for Zenith. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Oct 06, 2014 | Televison & Video
Sharp remote for audio tv vcr I want it to work for sharp stereo model number XLUH240
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
Check this link too. http://remotesearch.blogspot.com/
May 06, 2014 | Televison & Video
Universal remote codes for sharp tv, model number 32f641, original remote broken...went to a universal remote and cannot find the codes that manage the volume, power and ect.
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Feb 15, 2010 | Sharp 32F641 TV
Need code list for tvguide unvrsal remote
universal remote, rca tv program lennox dvd plaYER 2003
Feb 09, 2009 | Sharp Televison & Video
I need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Jan 13, 2009 | RCA Universal Remote Control
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
