Question about Linksys Wireless-G WRT54G Router
Need to connect to an ip camera remotely
I am told i need to forward ports, but how to do it?
    Sergeant:
  • 250 Answers
Http://www.pysoft.com/ActWebCamHelp/CameraSettings.htm
click the following link and follow the instructions carefully.
Posted on Jan 27, 2009
Port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
I have an edimax IC 7000 pt IP camera, I am having problems getting it to work using port forwarding..I have the latest sw & firmware loaded but seem to be going around in...
You have forward 2 ports.
forward port 80
forward port 443
make sure you have typed in the proper ip address for your camera,
ie. check the admin thingy to get your ip address for the cam.
then check if you can access it locally, then call a friend to see if they can access it remotely.
R.
Feb 11, 2010 | Edimax Computers & Internet
Trying to connect to remote camera. I go to a wifi spot and can connect. I try from my home and can't connect. What setting needs to be changed?
You cannot get to the outside of your router from inside the network. Use the internal IP address instead.
For instance:
Lets say you use http://camera.mydomain.com:8080 to get to the camera.
That URL points to your router which has some IP address. eg 80.180.23.234
You router forwards the request on port 8080 to the internal IP address of your camera eg. 192.168.1.45 an it is this address that you need to connect when inside the LAN.
Your need to replace the details above with those specific to your setup.
Nov 21, 2009 | NetGear WGR614 Wireless Router
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
Nov 13, 2009 | Home Security
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
Sep 12, 2009 | 2wire HomePortal 1100 Router...
Ip camera logon ptoblem
You might have forwarded the wrong ports of the camera to the wrong IP address. Make sure you assign static IP on the camera. Firewalls should be turned off as well.
Oct 26, 2008 | 2wire 1800HG Router (RG1800HG00)
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Oct 22, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Parker Vision Router WR1500
You need to forward the remote desktop port to your server. The Remote Desktop port is 3389. Go to the port forwarding section of your router and find out your Server's network IP address and assign it to forward the Remote Desktop port of "3389". Save your changes and try connecting again.
Sep 06, 2007 | ParkerVision SIGNALMAX WR1500...
Linksys Wireless-G WRT54G Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
