Question about Frigidaire Refrigerators
Model 241543939 frigidaire
Ice maker
SOURCE: My Frigidaire refrigerator (FRS20WNF)does not make ice anymore.
did you check your copper line in the back
Posted on Jan 14, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
Ice maker only making ice on quick ice frigidaire model LGHS2667KPO
What is your question that machine does not do quick ice in the ice maker!
Jan 18, 2017 | Frigidaire Refrigerators
Does the refrigerator filter filter the ice maker too
Hey friend, that's a great question!
For our Frigidaire refrigerators the water filter does in fact filter the ice maker too. The water enters your refrigerator from the water valve and then goes into your filter. It is then distributed between your ice maker and water tank. Hope this information has been helpful. -Matt
Jul 26, 2014 | Frigidaire Refrigerators
On my Frigidaire Ref/Frzr Model number FRS6LR5ew5-Ice maker is not working???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Frigidaire FRS23H7CS Side by Side...
I have a 2003 Fridgedaire Galley side by side Model # GS23HSZCWO SERIAL # LA32403124 when my ice cube maker empties some cubes get caught in the fins, it will not make more ice until they are manually...
Contact Frigidaire, they did have some revisions on some of their models for issues with the ice maker, at least explain the situation and they may help with the cost of yet another ice maker.
Also be sure the ice maker is mounted level and watch for hollow ice cubes that would indicate a low water pressure situation and not be a fault with the ice maker but an issue with the filter, water connection, or possibly the house pressure.
Jun 11, 2010 | Frigidaire Refrigerators
I have a frigidaire model#frs23r4a side by side fridge the ice maker makes very little ice and is not working at all now, any repair suggestions ??
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Ice maker only works for short time
I HAVE THE SAME PROBLEM WITH THE ICE MAKER FRIGIDAIRE FRS22WNC. IF ANYONE HAS AN IDEA HOW TO SOLVE IT PLEASE EMAIL ME TO HYATZFT91@AOL.COM
HIGHLY APPRECIATE IT.
NICK
Sep 07, 2007 | Frigidaire FRS23H7C Side by Side...
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
